  3. How to sort & compare the coordinates
  • Views 5153
Bala Sowjanya
Bala Sowjanya over 7 years ago
Can u tell me how to sort the coordinates and compare those in ascending or descending order.
Bala.
    Hi Bala,
    Your question is not exactly very clear. Coordinates of what? Ascending or descending order of what?  (x then y, or y then x, or what?).
  • Bala Sowjanya
    Bala Sowjanya over 7 years ago in reply to Andrew Beckett
    If pins are aligned in a sequence how to compare those coordinates y is constant & x is varies
  • lrlsk1
    lrlsk1 over 7 years ago in reply to Bala Sowjanya
    Hi Bala  this might help
    sortcar(yourList 'lessp) or 'greaterp  depending on how you want it.
    BR 'lrlsk
  • mbracht
    mbracht over 7 years ago
    sort by x in ascending order: myList = (sort myList (lambda (pt1 pt2) (lessp (car pt1) (car pt2))))
    sort by x in descending order: myList = (sort myList (lambda (pt1 pt2) (greaterp (car pt1) (car pt2))))
    sort by y in ascending order: myList = (sort myList (lambda (pt1 pt2) (lessp (cadr pt1) (cadr pt2))))
    sort by y in descending order: myList = (sort myList (lambda (pt1 pt2) (greaterp (cadr pt1) (cadr pt2))))
