  3. changing Ruler Display Type thru envSetVal
  • Views 15292
MalcolmWhite
MalcolmWhite over 7 years ago
Just wondering this question : I would like to change the value of ruler variable "rulerDisplayType" which lists as type 'cyclic in HELP menu
I can see the environment variable value with envGetVal, but I cannot change it with envSetVal - it appears I must address this by calling the
form where this setting is used by changing the value in leCreateMeasurementForm->displayType->value.
Just wondering why this situation works like this.  Is this because the variable type is 'cyclic ?  would it be changeable with envSetVal if it
was a boolean type ?
thanks
Malcolm
    Hi Malcolm,
    Looking at the create measurement command and form, it seems that the env variable is only looked at the very first time the command is used in a session. It probably should update the form each time it is used.
    I filed CCR 2043242 for this. You might want to contact customer support and ask for a duplicate to be filed on your behalf so that you can track this (always helps to get the request from a customer rather than just me internally).
  • MalcolmWhite
    MalcolmWhite over 7 years ago in reply to Andrew Beckett
    Greetings Andrew- thank you , I sent email to support@cadence.com asking to be added to this ticket discussion to view resolution.
