  3. SKILL code to change all the existing Metal layers to its...
  • Replies 9
  • Views 22038
SKILL code to change all the existing Metal layers to its corresponding fillBlock layer
ssram
ssram over 7 years ago
I'm a very beginner to the SKILL scripting, so just looking out for help to write a SKILL code to change all the existing Metal layers to its corresponding fillBlock layer in my layout.
As a start i wrote a few lines to check if the selected metal is "m2" in my layout
and to print "Layer name is m2" if it is
& if it is not, and print "Layer name is NOT m2"
The code is below, but its not doing what i intend it to, please help me fix it:
procedure(MetalToFillBlock()
let((m2)
if(geGetSelSet()~>layerName == m2
then
printf("Layer name is m2")
else
printf("Layer name is NOT m2"))
);let
);procedure
  • skillUser
    skillUser over 7 years ago
    There are a couple of issues with the code, the first is that variable 'm2' will be nil, but perhaps more importantly, geGetSelSet() returns a list, and so the result might be 'nil' or '("M2") or '("M2" "M2")' and so on.
    Perhaps something like 'forall' would be useful here?
      let((m2)
        m2 = "M2"
        if(forall(object geGetSelSet() object~>layerName == m2)  then
          printf("Layer name is %L for all selected objects\n" m2)
        else
          printf("Layer name is NOT %L for all selected objects\n" m2)
        ); if
      );let
    );procedure
    Hopefully this will help a little?
    Lawrence.
  • mbracht
    mbracht over 7 years ago
    For one geGetSelSet() returns a list and not a shape. Assuming that you did select a shape (and not an instance or via or whatever) you  need to get at the (first and only) element in the list in terms of a car statement.
    Moreover you initialize a variable m2 to nil in the let statement - but I assume you want to compare against the string "m2". So try this:
       let(()
          if(car(geGetSelSet())~>layerName == "m2"
          then
          else
       );let
  • ssram
    ssram over 7 years ago in reply to mbracht
    Thanks a lot for your quick response.
    But, this is a bit different from what i'm looking for.
  • ssram
    ssram over 7 years ago in reply to skillUser
    Thank you so much Lawrence, i think this is something closer to what i was looking for.
    Ultimately i was trying to find all the M2 in a selected set of groups and do certain operation. Basically, i need to change every M2 drawing to M1,M2&M3 fillBlock
    I was going to hard code this in the script. Do you have any idea how i could possibly do that?
    To tell you the whole idea, i need to convert all the existing "M2 drawing" to "M2-1 fillBlock", "M2 fillBlock" & "M2+1 fillBlock" so that i could have "M1 fillBlock", "M2 fillBlock" & "M3 fillBlock" wherever there was "M2 drawing"
  • ssram
    ssram over 7 years ago in reply to ssram
    So, is there a way i could check the list for m2 (because the selected list could have other layers as well) and whenever there is an m2 found, change its layer purpose to fillBlock and add m2-1 as well as m2+1 fillBlock ?
    Or, is there a way i could do these changes for all selected m2 in the list using a "forall" / "foreach" operation?
  • ssram
    I'm planning to do this by hard coding it for all the layers like:
    cv=geGetWindowCellView()
    shapes=geGetSelSet()
    dbLayerOr(cv list("m1" "fillBlock") shapes)
    dbLayerOr(cv list("m2" "fillBlock") shapes)
    dbLayerOr(cv list("m3a" "fillBlock") shapes)
    The above code is hard coded only for m2, but i should be able to do this only for m2.
    And once all the m2 are taken care, i should do the same for m3, m4, m5, etc.
    Thats where i'm stuck now, not knowing how to do it...
    Any help appreciated.
  • ssram
    Now i'm doing the following, but its coming wrong since my layer generation is not coming good.
    let((m0)
    m2 = "m2"
    foreach(object geGetSelSet() object~>layerName == m2
    );foreach
    );let
    );procedure
    I know its wrong since in dbLayerOr i'm mentioning shapes as the whole selected list. So my, foreach seems not working. I think i'm doing it horribly wrong.
  • ssram
    Finally i got it working...!
      m2list=setof(x geGetSelSet() x~>layerName=="m2")
      dbLayerOr(cv list("m1" "fillBlock") m2list)
    ;  dbLayerOr(cv list("m2" "fillBlock") m2list)
      dbLayerOr(cv list("m3a" "fillBlock") m2list)
      foreach(shape shapes
       when(shape->layerName == "m2"
    shape->lpp = list( "m2" "fillBlock" )
       );when
      );foreach
    );procedure
    But the only issue is that i need to have those lines for all the metal layers that i'm using. I'm not sure how to simplify it
    Andrew Beckett over 7 years ago in reply to ssram
    It's not entirely clear what the sequence of layer names are, but rather than parsing the layer name, and handling it that way, you could do:
      let((cv shapes layerName validLayers validBackwards below above newFig)
        validLayers=list("m1" "m2" "m3a" "m4" "m5") ; didn't understand what m3a was for
        validBackwards=reverse(validLayers)
          layerName=shape~>layerName
          ; don't convert first valid layer as there's no "below" layer
          when(member(layerName cdr(validLayers))
            below=cadr(member(layerName validBackwards))
            above=cadr(member(layerName validLayers))
            when(below && above
              ; use dbCopyFig rather than dbLayerOr as only dealing with one shape
              ; at a time.
              newFig=dbCopyFig(shape cv)
              newFig~>lpp=list(below "fillBlock")
              newFig~>lpp=list(above "fillBlock")
              shape~>purpose="fillBlock"
      t
    );procedure
    Note that this code is untested as I don't have anything suitable to try it on - but hopefully it gives you the hint as to how to do it.
