  3. What am i doing wrong?
  • Views 15673
ssram
ssram over 7 years ago
If i do
shapes=geGetSelSet()~>layerName
i get all the selected layer names. And if my output is something like
("m0" "m0" "m0" "m0" "m1" "m1" "m2" "m2" "m0" "m2")
how do i get only the list of "m0" ?
  • RK56
    RK56 over 7 years ago
    You can use "setof" to filter a list
    setof(x geGetSelSet() x~>layerName=="m0")
    The above line will return a list of shapes (db IDs)  that are only of layer "m0".
    There also another function named "exists" which works similarly, but I prefer "setof".
    -Ramakrishnan
    Andrew Beckett over 7 years ago in reply to RK56
    I should point out that exists doesn't really work similarly - exists returns the remainder of the list which starts with the first element that matches the condition, whereas setof returns only the elements of the list which match the condition...
    Sorry to be pedantic - just didn't want ssram to head off in the wrong direction.
  • RK56
    RK56 over 7 years ago in reply to Andrew Beckett
    Thanks Andrew. I did not know that.
  • ssram
    ssram over 7 years ago in reply to RK56
    Thank you Ramakrishnan. I got it working!
