  3. adding Layersets to bindkeys
  • Views 19356
ICLondon
ICLondon over 7 years ago
I love layersets.  I have unique layersets for vias (ie "via1" = m1 (draw, pin, fill), via1, & m2 (draw, pin, fill)), "base" layers, all "fill", all "pins", etc.
I would like to be able to map and toggle them with bindkeys (or get some skill code where I could have the same functionality), as well as set the active layer for each - this would increase my productivity dramatically, imho.
Here is some code that Rupinder sent me a couple years ago (i had some time-off), but I am not certain how to implement it to get it working:
procedure( setActiveLayerAndLayerSetVisibility( metalLayer visible)
                let( (layer)
                                sprintf( layer "m%d drawing" metalLayer)
                                sprintf( layerSet "v%d" metalLayer )
                                pteSetLSVisible("All Layers" nil)
                                pteSetLSActive(?layerSets layerSet ?deactivateOthers t)
                                pteSetLSVisible(layerSet visible)
                                ;uncomment the following lines if you want this function to set active layer and start wire command
                                ;pteSetActiveLpp( layer )
                                ;leHiCreateWire()
                ) ;let
) ;procedure
Then you can add bindkeys to call the above function and pass different numbers and visibility status. For example, to activate layerSet v2, pass number 2 and t as arguments to the function call. “t” means the visibility of layers is on. “nil” means visibility is off.
hiSetBindKey "Layout" "<key>2" "setActiveLayerAndLayerSetVisibility( 2 t )"
hiSetBindKey "Layout" "<ctrl>2" "setActiveLayerAndLayerSetVisibility( 2 nil )"
Similarly, you can assign bindkey 3 to set v3 as active layerSet.
My first question is about the "%" - is this a generic string?  If so, how would this procedure include fill and pins for both metal layers associated with, for example, via1 (m1 &m2)?
Also, what does the "?" do? Lastly, would the same procedure work for "all pins", "all fill", and "all base layers?"
Thank you in advance to anyone interested in this topic!
London
    Andrew Beckett over 7 years ago in reply to ICLondon +1
    Hi London, I'm not sure how others will be able to try them out, since you didn't provide the definition of ctkToggleAllLayersObjects or ctkToggleLayers? Regards, Andrew.
    Hi London,
    First of all, I moved this into a suitable forum, since it wasn't a "Forum Questions, Suggestions and Feedback" question, it was a technical question about Custom IC SKILL. If you ask in the forum related to issues with the forum itself, then you're unlikely to get an answer.
    The % is a format control string as part of the sprintf/printf/fprintf function. The second argument to sprintf is a string which describes the format of the string you're trying to build. Using "%d" means pick the next argument and insert an integer converted to a string. It broadly follows the C sprintf/fprintf/printf functions, but the easiest way to find it is to use (in IC617 and later) cdsFinder, type printf, and then select printf in the matches and hit "More Info". On that page, follow the link to Common Output Format Specifications.
    The ? before a word in this case means that the function is called with a keyword argument, which means that the arguments are passed by name rather than by order. Some functions are defined that way.
    The bit using % only relates to setting the active layer. You might be better off just having a simpler function:
    procedure(MyMakeLayerSetVisible(layerSet)
      pteSetLSVisible(layerSet t)
    Then you can just use MyMakeLayerSetVisible("via1") or whatever you've called your layer set.
  • ICLondon
    ICLondon over 7 years ago in reply to Andrew Beckett
    Hi Andrew - thank you sooo much! Working on this...
  • ICLondon
    ICLondon over 7 years ago in reply to ICLondon
    Hi Andrew - between the two codes given by yourself and Rupinder, I was able to learn enough to realize there might be an easier way to attain my goal (and also realized how little I understand SKILL!).  As a work around, I was able to get the following bindkeys to work:
    hiSetBindKeys( "Layout" list(
    list("<Key>`" "(ctkToggleLayers (list \"base_all\" \"v0_all\" \"m1_all\"))")
    list("<Key>1" "(ctkToggleLayers (list \"m1_all\" \"v1_all\" \"m2_all\"))" "drdEnablePixelThreshold(!drdIsPixelThresholdEnabled())")
    list("<Key>2" "(ctkToggleLayers (list \"m2_all\" \"v2_all\" \"m3_all\"))")
    list("<Key>3" "(ctkToggleLayers (list \"m3_all\" \"v3_all\" \"m4_all\"))")
    list("<Key>4" "(ctkToggleLayers (list \"m4_all\" \"v4_all\" \"m5_all\"))")
    list("<Key>5" "(ctkToggleLayers (list \"m5_all\" \"v5_all\" \"m6_all\"))")
    list("<Key>6" "(ctkToggleLayers (list \"m6_all\" \"v6_all\" \"m7_all\"))")
    list("<Key>7" "(ctkToggleLayers (list \"m7_all\" \"v7_all\" \"m8_all\"))")
    list("<Key>8" "(ctkToggleLayers (list \"m8_all\" \"v8_all\" \"m9_all\"))")
    list("<Key>0" "(ctkToggleAllLayersObjects 'none (list \"base\" \"metals_all\" \"vias_all\"))")
    list("<Key>-" "(ctkToggleLayers \"pins_all\")")
    list("<Key>=" "(ctkToggleLayers \"fill_all\")")
    )) ;; hiSetBindKeys
    It works perfectly!  It took a while and some luck to figure out how to list multiple variables in one line, and I had to guess to get the "pins_all" and "fill_all", but ultimately it is exactly what I was looking for.  I encourage anyone who is looking for more effective bindkeys to try these out!
    Thank you so much for your support Andrew - enjoy!
    London
    Hi London,
