  3. Scheme reduce or fold in Skill
  • Views 15579
jpyams
jpyams over 7 years ago
I know Skill implements common Scheme functions like map() (as mapcar) and filter() (as setof).
Is there a Skill equivalent of Scheme's reduce-left(), reduce-right(), fold-left(), or fold-right()?
I searched the docs and the community, but I couldn't find anyone else asking this question.
    Andrew Beckett over 7 years ago +1
    There are some posts on this already. Here's one that discussed foldr , and another that has an implementation of foldl (and foldr) . There's nothing built-in, but easy enough to implement should you…
    There are some posts on this already. Here's one that discussed foldr, and another that has an implementation of foldl (and foldr).
    There's nothing built-in, but easy enough to implement should you need to.
  • jpyams
    jpyams over 7 years ago in reply to Andrew Beckett
    Ok, thanks!  It is simple enough to implement, but I figured I didn't want to reinvent the wheel if Skill already had something.
