  3. Skill code to read instance and transistors from netlis...
  • Views 15018
Skill code to read instance and transistors from netlist
Casp
Casp over 7 years ago
I am writing a skill code to read the corner and temperature simulation results from adexl in skill and then do post processing and identify which transistors are out of saturation.
I know we can do it via Circuit Conditions but that is too much work for 20 corner and temperature simulations.
My output should look like
Process  |  Temperature |  OutOfSaturation
sf            |    -25              |    I26/MN21
fs            |     85              |    I33/MP22
You can also tell me if there is adexl database function that can do it easily
Regards
Ralph
    Hi Ralph,
    ADE XL has the checks and asserts capability which would be a very good way to set up and report this information without needing to write any SKILL at all.
    There's a Rapid Adoption Kit for this - Check & Assertions
