  3. How to pass a value from a procedure to another?
  • Subscribers 150
  • Views 16949
sruzzu
sruzzu over 7 years ago
Hi everybody,
I'm trying to make a skill that renames all the selected objects in the layout with a value that I insert in the form and merging it with a counter.
For example: If I have 30 copied resistors (I1, I2,I3,..., I30), I want to rename them R0.1, R0.2, ..., R0.30 .
At first try I made a single procedure that creates the form and renames. That seemed to work correctly but, if I press the button "cancel" in the form, the procedure continues and renames all the selected objects with the value of the counter (1,2,3...,30).
So I decided to make two procedure, one for the creation of the form and another for the execution of the renaming.
There is only one problem I can't really figure out: how can I pass the name, that I wrote in the form, to the procedure of execution?
Hope someone can help me.
Bye bye :)
Here it is my procedure:
/*CREATE FORM*/
procedure( change()
let((myform changeName)
/*CHECK LAYOUT VIEW*/
if( (geGetEditCellView()~>cellViewType != "maskLayout")
 then hiDisplayAppDBox(
   ?name 'errorbox2
   ?dboxBanner "Errore"
   ?dboxText sprintf( nil "La procedura funziona solo con Layout Window")
   ?dialogType hicErrorDialog
   ?buttonLayout 'Close
   ?dialogStyle 'modal
changeName=hiCreateStringField(
                ?name 'changeName
                ?prompt "Inserire nome"
  ?defValue ""
  ?editable t
  ;?callback "esec()"
 hiCreateAppForm(
            ?name 'myform
            ?formTitle "Change Instance Name"
           ?fields list( changeName )
     ?callback "exec(changeName~>value)"
hiDisplayForm(myform)
/*EXECUTION RENAMING*/
procedure( exec()
let( (changeName nome num)
nome = changeName~>value
if( (rexMatchp("symbol" buildString(geGetSelSet()~>viewName)) == nil) && (rexMatchp("lay" buildString(geGetSelSet()~>viewName)) == t)
  then for(i 1 geGetSelSetCount()
   sprintf(num "%d" i)
   geGetSelSet()~>name = strcat(nome num)
   geSelectNextInSelSet()
  • francktellier
    francktellier over 7 years ago +1
    Hello, You must add an argument in the exec procedure , and remove the definition of "nome" in the body of the procedure please try the following syntax : procedure( exec(nome) let( (changeName…
  • skillUser
    skillUser over 7 years ago in reply to sruzzu +1
    Hi, Rather than using for() with a counter, simply iterate over the selected items using foreach(), e.g. foreach(obj geGetSelSet() ...) - it looks as though your code is actually changing what is selected…
  • francktellier
    let( (changeName  num)
    ;;;nome = changeName~>value
       sprintf(num "%d" i)
    Best Regards
  • sruzzu
    sruzzu over 7 years ago in reply to francktellier
    Hello Franck,
    thanks a lot for your response.
    It works! Can you explain why should I do it? I don't understand clearly what I have to put as argument of a procedure in general.
    Another thing which I can't understand is a warning that appears. It looks like that the exec enters in a loop and tries to overwrite the name of the first selected item since the end of the counter.
    That's really strange.
    Thank you again Slight smile
  • skillUser
    Rather than using for() with a counter, simply iterate over the selected items using foreach(), e.g. foreach(obj geGetSelSet() ...) - it looks as though your code is actually changing what is selected?
    I have not gone through your code in detail but hopefully this alternative approach will help?
    Lawrence.
  • sruzzu
    sruzzu over 7 years ago in reply to skillUser
    Hi Lawrence,
    thanks you very much for your answer. It works!
    Stefano
