  3. abIPar.il issue of geGetTopLevelCellView() returning ni...
  • Views 16081
abIPar.il issue of geGetTopLevelCellView() returning nil
DavidLou
DavidLou over 7 years ago
hello experts,
happened to notice the code Andrew made in community.cadence.com/.../1323814 .
we use this abIPar procedure to collect info from cdf parameters and display them in schematic/symbol. that's all working fine until I have ade session and when I click "run" in ade, all these display procedure go "nil" which traced down to this geGetTopLevelCellView() returning nil. once I do a re-draw then all the display come back to normal life again.
so wonder why would geGetTopLevelCellView() fail in such occasion?
P.S., both IC6.1.7-64b.500.21 and IC6.1.7-64b.500.9 have this problem.
thanks,
David
    Hi David,
    The reason is that there are several places in the code where it depends on the current window to determine the top cellView, the hierarchy path to this instance, the simulation session associated with the window and so on. Unfortunately (and this is a limitation since I originally wrote the code in 2003) it is not going to do the right thing if the window being redrawn is not the current window - which is quite likely when using ADE and running a simulation because it refreshes the schematic windows in case any annotations need to be redrawn.
    I'm doing some checks to determine whether I can make public the mechanism for determining the current display window and then I'll update the code.
    It's similar to a problem that CADcasualty had recently in Annotations are just way too overpowering
  • DavidLou
    DavidLou over 7 years ago in reply to Andrew Beckett
    got it, thanks Andrew. keep us posted if viable options becoming available.
    thanks,
    David
  • CADcasualty
    CADcasualty over 7 years ago in reply to DavidLou
    Hi Andrew. Given that this thread is related to my other post, I was wondering if you've had any success on obtaining access to the current display window mechanism...
    Andrew Beckett over 7 years ago in reply to CADcasualty
    I know how it works right now, but we're having a discussion as to whether the current method should be made public or whether we should make something more sustainable/supportable. We always have to be careful about making an internal mechanism public without careful thought because then it comes with a reasonable expectation of future support. CCR 2061032 is asking for a public mechanism for finding the current display window, and that hasn't reached a resolution yet.
