  3. Redirect poport to variable
  • Views 16622
liorscotland
liorscotland over 7 years ago
Hello all.
One can direct the poport into a file, if needed.
However, can one redirect this into a variable, directly?
    Andrew Beckett over 7 years ago +1
    Hi Lior, How about this? /* abPoportToString Author A.D.Beckett Group Custom IC (UK), Cadence Design Systems Ltd. Language SKILL Date Mar 07, 2019 Modified By A macro to capture any output to…
    Hi Lior,
    How about this?
    /* abPoportToString
    Author     A.D.Beckett
    Language   SKILL
    Date       Mar 07, 2019
    Modified
    By
    A macro to capture any output to poport (e.g. standard output) from
    the code within the body of the call into a string (which is returned)
    For example:
    data=abPoportToString(
        ; code inside just writes to poport
        foreach(file sort(getDirFiles("/bin") 'alphalessp)
          printf("%s\n" file)
    This will have all the file names in the directory /bin in a string
    with newline between each file name, as produced by the printf.
    So you could then do: printf("%s" data) and see the same text.
    SCCS Info: @(#) abPoportToString.il 03/07/19.17:04:14 1.1
    (defmacro abPoportToString (@rest body)
      `(let ((_outputStringPort (outstring)))
         (unwindProtect
           (dynamicLet ((poport _outputStringPort))
                       ,@body
                       (getOutstring _outputStringPort)
           (close _outputStringPort)
  • liorscotland
    liorscotland over 7 years ago in reply to Andrew Beckett
    Hi Andrew. I'll give it a try..
  • liorscotland
    liorscotland over 7 years ago in reply to liorscotland
    Hi Andrew. Works as expected. Thanks!
