  3. handling large layouts : use of groups versus instance ...
  • Views 18455
handling large layouts : use of groups versus instance mosaic
MalcolmWhite
MalcolmWhite over 7 years ago
Greetings - first , apology if this isn't the right forum for this : Wondering this scenario : in the situation where someone is working at an upper level layout cell with large amounts of data experiencing significant lag in performing basic layout operations , what is the best manner to handle repeated layout structures in terms of reducing lag time of memory access for data : Groups or mosaics ? mostly trying to learn how groups are handled in the system.  thanks.
    For small numbers of objects, it doesn't matter too much. However, for very large numbers of repeated objects then a mosaic is more efficient. In essence a group (I assume you mean a figGroup in the database) is just a means of creating a relationship between a number of flat objects - so if you have a group with a 100 x 200 instances, you still have 20,000 instances present in the design. If you have a mosaic with 100 x 200 in the array, there's a single database record describing that array, and then it's expanded at rendering time rather than needing expanding in the database.
    There are however some limitations with mosaics if you're using a connectivity-driven flow (such as Virtuoso Layout Suite XL) because that only allow mosaics if the connectivity to every instance in the mosaic is identical (this is a limitation of what can be represented by mosaics in the database rather than a limitation of VLS XL). Also, mosaics have to be an array of instances, whereas a figGroup can contain anything (well, any figure)
