  3. Highlighting specific paths across nets and instances in...
  • Views 19113
Highlighting specific paths across nets and instances in schematics
Herge
Herge over 7 years ago
Background
The idea is to create a "current-path"  highlighter. Out of simulations we have "current paths" as collections of device terminals on a certain net where a given current is flowing through. Not all terminals on this net have current flowing through only some devices participate in the current path, that will also span multiple nets and multiple devices. But let's concentrate on a single net, and the associated list of device terminals through which the current is flowing.
  1. We want to highlight only those segments on the net which form paths linking the terminals listed as being active.
  2. We want also to mark the device terminals with in-coming or out-going arrows depending on the sign of the current, also annotated in two lists
Present understanding of the problem
After reading through documentation and question/answers posted on the discussoin fora, I think the situatoin is as follows :
  1. In order to get the list of all wireSegments, we would have to query the figures from the nets.
  2. In order to "understand the connectivity of wireSegments, we need to find how they share vertices based on the point coordinates. There is no other way to find that two wireSegments share a common vertex.
  3. In order to "understand the connectivity of wireSegments to device terminals", we need to obtain the bounding boxes of those terminals in the coordinate space of the cellview (not that of the instance master) and find which wireSegment has a vertex falling in that box.
  4. Once that is done we can build a graph model representing the connectivity of wireSegments and terminals and apply some search algorithm in order to find which wireSegments participate in the wanted paths.
  5. Once we have the list of segments we can include them in some highlight group.
Questions
I would like to get your feedback on the points above :
(a) Is the procedure outlined above correct ?
(b) Did I miss something in the DB organization which would allow us to implement a simpler solution ?
(c) Does anyone have some scipts or programs to do this ?
Looking forward to your inputs. Thanks,
Renaud
  • skillUser
    skillUser over 7 years ago +1
    Hi Renaud, [a] I believe that your understanding is correct for (1) and (2) - you query the figures on a net to get the wire/line segments (is this in a schematic, I'm guessing 'yes'), and as far as…
  • skillUser
    Hi Renaud,
    [a]
    I believe that your understanding is correct for (1) and (2) - you query the figures on a net to get the wire/line segments (is this in a schematic, I'm guessing 'yes'), and as far as I know there is no storage of sequence of one net segment to another so, yes, you would need to follow connectivity through the common vertices.  If you didn't need to limit to only certain parts of the net then you could easily mark/highlight the whole net.  Likewise for (3) the overlap of the pin box (device terminal) with the line (wire segment), I think you need to work this out rather than being able to pull it directly from the database. It looks like (4) and (5) are correct.
    [b]
    I don't think that you are missing anything, a certain amount of 'manual labor' is required, even though some of the database storage is convenient.
    [c]
    Here is a snippet of code that can be used to find a 'wire' object that overlaps an instance pin, where "inst" is the instance database object ID
    foreach(instTerm inst~>instTerms
      if(pins = instTerm~>term~>pins then
        dir = instTerm~>direction
        unless(onep(length(pins))
          warn("%s - Terminal %s has more than one pin, using first one\n" getCallingFunction() instTerm~>name)
        ); unless
        pinCenter = centerBox(
          dbTransformBBox(car(pins)~>fig~>bBox inst~>transform))
        shapes = dbShapeQuery(cv list("wire" "drawing") list(pinCenter pinCenter) 0 0)
        if(shapes then
          wire = car(shapes)
    Hopefully this will help you a bit.
    Best regards,
    Lawrence.
  • Herge
    Herge over 7 years ago in reply to skillUser
    Thank you. Very helpfull.
    One more question: do you think it is possible to augment the data-base by storing "custom" data, for example on the wire-segments in order to speed up the current highlighting operations (at a later time or when doing it multiple times) ?
    And also a second question: I assume that all operations detailled previously and above could be triggered from an external program using OA access functions ?
    Renaud
  • skillUser
    skillUser over 7 years ago in reply to Herge
    Hi Renaud,
    Yes, this is one of the great things with the Cadence database and SKILL - you can 'tag' objects or add custom properties in a persistent way that will be stored in the database for later recall - you can use the API functions (dbCreateProp, dbCreateEnumProp, dbCreateHierProp, dbCreateRangeProp) to create data, or you can use ~> and assignment (e.g. netId~>myHilightProp = t).
    Best regards,
    Lawrence.
    Andrew Beckett over 7 years ago in reply to Herge
    You could store user properties on the wire segments, for example, or create groups to store related data. Of course, you might have some synchronisation issues as users edit the data.
    Even if you could use an external program using OA access functions (information on which would come from Si2 rather than Cadence since we don't document them ourselves), that external program can't create hi lights and things like that because those APIs are only available within Virtuoso. So I'm not sure it would be particularly beneficial to do it outside.
