  3. Trying to fix grid error in the entire library
  • Subscribers 148
  • Views 1532
FormerMember
FormerMember over 7 years ago
Hi All,
I am trying to fix grid error of labels in my library using a skill code.
I have tested the below code with a particular cell view, and it is working fine.
libName="test"
res=0.01
cv=geGetWindowCellView()
foreach( txtShp setof(shp cv~>shapes shp~>objType == "textDisplays")
unless( onGrid( car( txtShp~>xy ) res ) && onGrid( cadr( txtShp~>xy ) res )
;printf("Fixing text %s \n" txtShp~>theLabel )
txtShp~>xy = snapClosest( car( txtShp~>xy) res):snapClosest( cadr( txtShp~>xy) res)
But when I try to modify this code to work on my entire library, it does not gives any error but nothing happens on the cells
libName="test"
res=0.01
procedure( rfipFixOffGridText(cv res )
let( ()
libID=ddGetObj(libName)
all=setof(cells libID~>cells member("layout" cells~>views~>name))
foreach(cell all
cv = dbOpenCellViewByType(libID~>name cell~>name "layout" "" "a")
rfipFixOffGridText(cv res)
dbSave(cv)
dbClose(cv)
Please tell me where I am going wrong in my approach.
Utkarsh
    The line:
    should be:
    foreach( txtShp setof(shp cv~>shapes shp~>objType == "textDisplay")
  • FormerMember
    FormerMember over 7 years ago in reply to Andrew Beckett
    Thankyou Andrew,
    It worked.
