  3. deRegUserTrigger
  • Views 14874
deRegUserTrigger
Nirmal Kumar
Nirmal Kumar over 7 years ago
Hi ALl,
I need to set a trigger function when layout opens. Also I need to set a trigger function when library manager opens,
For layout trigger I use the below command
deRegUserTriggers( "maskLayoutXL" nil nil 'moveStretchObject)
deRegUserTriggers( "maskLayout" nil nil 'moveStretchObject)
But I need to set the trigger only once. i.e first time when the layout opens. Also when I open layout window from Lib Manager this trigger works. but when I launch layout_XL from layout window the trigger does not work.
I need to open in layout_XL mode from libary manager. only then the trigger function works.
I am also trying to find how to set the rigger function when the lib manager opens.
Can anyone please help me with this.
Nirmal.
