  3. not able to use cds_innersrr when corners are added to adexl...
  • Views 14207
not able to use cds_innersrr when corners are added to adexl simulations
MartyAb
MartyAb over 7 years ago
I have been using the Matlab Virtuoso toolbox for a while now and getting very comfortable with the structure that cds_innersrr returns data in different analysis types. I could use matlab to make more sophisticated data processing on results of the simulations. Now I am trying to run same simulations and sweeps but over different process and temperature corners and suddenly everything looks different. Seems like corner data is not stored similar to doing the same as sweeping a global variable in the analysis. On a typical sp analysis I could use cds_innersrr(resdir,'sp-sp','s11') to return a structure with 'freq' and 'S_Param'  fields being matrices, but now adding the corner the same command gives a structure with one field, 'value' which includes the names of different corners only. No simulation data. I appreciate it anyone could point me to the right direction. Is there any extra argument to cds_innersrr() which takes corners into account? Thanks in advance
