  3. Is there a function that can modify the existing prBoundary...
  • Views 15802
Is there a function that can modify the existing prBoundary Object in layout??
Abhjith
Abhjith over 7 years ago
Hi tried to push new co-ordinates for its bBox, but doing that it will work for normal layers and same thing is not working for "objects" in my case its prBoundary object.
I have to do it for more than 1000 layouts.
Regards
Abhijith
    Hi Abhijith,
    Two things - first, it's a polygon rather than a rectangle, so you need to specify a list of points rather than a bBox (so four points for a rectangular boundary), and secondly you can't do it via ~>points. Instead  you need to use the dbSetBoundaryEdge function to update the boundary:
    dbSetBoundaryEdge(cv~>prBoundary list(0:0 70:0 70:90 0:90))
  • Abhjith
    Abhjith over 7 years ago in reply to Andrew Beckett
    Thats  great, I got it working now.
    Thanks lot for your quick reply.
    Regards
    Abhijith
