  3. Conditional method definition
  • Views 16218
Curtisma
Curtisma over 7 years ago
I am trying to conditionally define a method by using a macro.  However, I keep getting an error with some variation of the body variable not getting expanded to the rest of the arguments.  I have tried using the ",@" and the "," operators along with no operator and using the apply function and none seem to work.  Any idea how to implement this or if it is possible?
; Skips defining the current test if the current project does not match the
; project name specified
defmacro(utDefTest (@key project lib @rest body)
    prj = SkyPrj->newFromEnv(nil)
    prj = prj->Name
    if(!project || project && prj == project then
        'defmethod(,@body)
        ;'defmethod(,body)
        ;'defmethod(body)
        ;apply('defmethod ,@body)
    else
        warn("Test not defined: %s" car(body))
Test Example:
utDefTest(test_macro ((testObj pkgTechTests)) let(()
    1+1
Error Example:
*Error* defmethod: too few arguments (at least 2 expected, 1 given) - (\@body)
Curtis
    Andrew Beckett over 7 years ago +1
    Curtis, The issue is that the quote before defmethod should be a backquote not a normal quote. In other words `defmethod(,@body) not 'defmethod(,@body). If you use the normal quote, then nothing is evaluated…
    Curtis,
    The issue is that the quote before defmethod should be a backquote not a normal quote. In other words `defmethod(,@body) not 'defmethod(,@body). If you use the normal quote, then nothing is evaluated within the following list; if you use backquote, the following list isn't evaluated unless it's preceded by comma or comma-at. The backquote character is essentially a macro itself which selectively evaluates.
    You should also make prj a local variable within the macro, as otherwise it's setting a global variable at macro expansion time:
        let((prj)
            prj = prj->Name
                `defmethod(,@body)
            else
  • Curtisma
    Curtisma over 7 years ago in reply to Andrew Beckett
    That did it, thanks!
