  3. Creating BooleanButtons from a list
  • Views 15245
climbnc
climbnc over 7 years ago
I have the following list
listA = list("testA" "testB"  "testC")
and i want to create a boolean button for each list item to be able to add to a form.
i tried creating the buttons using the following and then adding the button to the form using hiAddField.  I believe the issue is that i do not have a variable name for the hiCreateBooleanButton.
Im not sure how to have the variable name of hiCreateBooleanButton be the same as the variable buttonName.
Can anyone point out what i am missing or doing wrong please?
foreach(item listA
            buttonName = stringToSymbol(strcat(item "_booleanButton"))
            hiCreateBooleanButton (
            ?name buttonName
            ?buttonText item
Chris
    Hi Chris,
    The variable that is used to store the fields doesn't require any special name - it's just a means of holding it prior to adding the field. So you could do either:
    foreach(item listA
      newButton=hiCreateBooleanButton(
        ?name buttonName
        ?buttonText item
      hiAddField(yourForm newButton) ; or use the 2D info if needed
    or you could do:
    newButtons=foreach(mapcar item listA
        ?name buttonName
        ?buttonText item
    In this second case, newButtons would be a list of the newly created buttons, and you could then use hiAddFields to add them, or do a foreach over newButtons to add them one at a time. You could potentially do something like this if you want the field positions:
    y=30
      y=y+30
      list(
          ?name buttonName
          ?buttonText item
        0:y 150:30 100
    hiAddFields(yourForm newButtons)
  • climbnc
    climbnc over 7 years ago in reply to Andrew Beckett
    Thank  you Andrew.  This was very helpful.
