  3. Passing CDF parameters into subcells
  • Views 18800
anomolousDoug
anomolousDoug over 7 years ago
I have a hierarchical pcell that requires parameters to be passed through from the property sheet into lower level pcells containing unknown parameters, but the parameters do not update with any changes or apply.
Currently, this is the approach:
cv=dbOpenCellViewByType( library subcell "layout" "maskLayout" "r")
subParams=magicallyGetParameters( cv); Extract list of parameters
foreach( parameter subParams
   cdfCreateParam( cdf blah blah blah))
dbClose(cv)
cdfSaveCDF( cdf)
pcDefinePCell( list( library "TopPcell" "layout")
   ((paramA int paramA)
   (paramB int paramB)
(subParams ilList subParams))
dbCreateParamInstByMasterName( pcCellView lib subcell "layout" "Q1" 0:0 "R0" 1 subParams)
The subParams list never updates, and only the default values ever go in, even though all sub parameters are extracted and displayed correctly in the CDF form.
I imagine this probably has something to do with callbacks, but I just don't really understand them, or even know when they're necessary.
  • mbracht
    mbracht over 7 years ago
    Hi...May I see what exactly the subParams list looks like. The PCell parameters passed to dbCreateParamInstByMasterName() need to be a list of sublists with each sublist being a 3 element list identifying param name, type and value.
  • anomolousDoug
    anomolousDoug over 7 years ago in reply to mbracht
    Thanks for having a look. The format of the subParams list is correct according to your description, but the values contained within are stale, and do not get updated with any change in the parameter form. However, the parameters at the top level do get updated correctly. The form of passthrough subParams and the lower level pcells are disconnected somehow. I saw an example of how to do this when using a mosaic containing the subcells by using dbReplaceProp on mosaic->instanceList, but that does not apply in this case as these subcells are flat placements, and I don't know what the equivalent would be. It seems things get more complicated when you introduce hierarchy inside a pcell.
    Andrew Beckett over 7 years ago in reply to anomolousDoug
    The main issue here is that you've not really provided enough information to know what you're doing wrong (or right). If you can't post the complete example here, I suggest you contact customer support.
  • anomolousDoug
    anomolousDoug over 7 years ago in reply to Andrew Beckett
    Here is a more complete example of what I'm trying to accomplish. In the following code, there are 2 pcells. "rectangle" is the higher level cell that parses the parameter list in the lower cell, and in turn calls the lower level cell "subRectangle" attempting to pass the cdf parameters through to the lower cell. I've gone through several unsuccessful iterations, but this is where it stands now:
    let(()
    when((cell = ddGetObj("CCSsandbox" strcat("rectangle") nil nil nil "a")) &&
    (cdf = cdfGetBaseCellCDF(cell) || cdfCreateBaseCellCDF(cell)) cdfDeleteCDF(cdf)
    cv=dbOpenCellViewByType( "CCSsandbox" "subRectangle" "layout" "maskLayout" "r")
    subParamList=list()
    if( cv->isParamCell then
    params=car( setof( param cv->prop param->name=="parameters"))
    foreach( mapcar param params->value
    k=symbolToString( type( param->value))
    cond(( k=="flonum" k="float")
    (k=="fixnum" k="int"))
    subParamList=append( subParamList list( list(param->name k param->value))))
    dbClose(cv)
    foreach( parameter subParamList
    cdfCreateParam(cdf
    ?name car( parameter)
    ?type nth(1 parameter)
    ?defValue nth(2 parameter)
    ?parseAsNumber "no"
    ?prompt car( parameter)
    ?parseAsCEL "no")))
    cdfSaveCDF(cdf));when
    pcDefinePCell( list(ddGetObj("CCSsandbox") "rectangle" "layout")
    (subParamList ilList subParamList))
    let((xPitch yPitch element subParams)
    element=dbOpenCellViewByType( "CCSsandbox" "subRectangle" "layout")
    break()
    dbCreateParamInst( pcCellView element "" 0:0 "R0" 1 subParamList)
    dbClose( element)
    );pcell let
    );pcDefinePCell
    );cdf let
    let((W H)
    when((cell = ddGetObj("CCSsandbox" strcat("subRectangle") nil nil nil "a")) &&
    W=1.0
    H=1.0
    ;Default parameter values:
    cdfCreateParam(cdf
    ?name "W"
    ?type "string"
    ?defValue sprintf(nil "%.3f" W)
    ?parseAsNumber "yes"
    ?prompt "Width:"
    ?parseAsCEL "yes")
    cdfCreateParam(cdf
    ?name "H"
    ?type "string"
    ?defValue sprintf(nil "%.3f" H)
    ?prompt "Height:"
    ?parseAsCEL "yes")
    pcDefinePCell( list(ddGetObj("CCSsandbox") "subRectangle" "layout")
    (W float W)
    (H float H))
    let(()
    dbCreateRect( pcCellView list( "y0" "drawing") list( 0:0 W:H))
    );pcell let
    );pcDefinePCell
    );cdf let
  • anomolousDoug
    subParamList (("H" "float" 1.0) ("W" "float" 1.0) )
