  3. String manipulation question
  • Views 16904
CADcasualty
CADcasualty over 7 years ago
I have a procedure that returned a string into a variable named myString:
myString="abc\\ndef"
I want to take myString and scan for the "\\n" part and change it to "\n" and copy the result into myNewString so that I end up with:
myNewString = "abc\ndef"
The intent here is to print myNewString and have it appear as 2 lines of text ("abc" and "def") - I'm sure this is simple, but for the life of me I can't figure it out :-(.
  • skillUser
    skillUser over 7 years ago
    The second item is easy enough but I haven't got time to wrestle with the first - you will most likely need "\\\\" to find the "\\" pattern, and then need some substitution, both of these using the pcre* functions.
    parseString(myNewString "\n")
    => ("abc" "def")
    Best regards,
    Lawrence.
  • mbracht
    mbracht over 7 years ago
    Can you try this one:
    (pcreExecute (pcreCompile "(.*)\\\\n(.*)" ) myString)
    (pcreSubstitute "\\1\\2" )
    Max
    Andrew Beckett over 7 years ago in reply to mbracht
    Or simpler, just do:
    badReturn=pcreCompile("\\\\n")
    myNewString=pcreReplace(badReturn myString "\n" 0)
  • CADcasualty
    CADcasualty over 7 years ago in reply to Andrew Beckett
    Wow - thanks everybody! The pcre stuff solved my problem. I did try the parseString thing beforehand but it messed things up when the random text either side of the \n contained the character "n"
