  3. Passing skill variable to shell command
  • Views 17457
GDCRA
GDCRA over 7 years ago
I want to run perl excecutable from skill procedure. I have my design name in  variable mycell, library name in mylib and runpath in myrunpath variable.
I am running following way
CommandLine="netlistextract -library mylib -design mycell  -rundir myrunpath"
cid=ipcBeginProcess(CommandLine)
Looks like skill variable are not getting evaluated when i do CommandLine. How do I fix it ?
Is there elegant way to do what I am trying to do here ?
GC
  • skillUser
    skillUser over 7 years ago +1
    Hi GC, You can build the 'CommandLine' variable using sprintf() (or strcat, depending on your inputs or preferences), for example: sprintf(CommandLine "netlistextract -library %s -design %s -rundir…
  • skillUser
    Hi GC,
    sprintf(CommandLine "netlistextract -library %s -design %s -rundir %s" mylib mycell myrunpath)
    cid = ipcBeginProcess(CommandLine)
    Best regards,
    Lawrence.
  • GDCRA
    GDCRA over 7 years ago in reply to skillUser
    Thanks Lawrence. That worked like charm. Is there way I can monitor output of above command in CIW ?
    I was using ipcReadProcess(cid) but I need to enter this line multiple time.
    GC
  • skillUser
    skillUser over 7 years ago in reply to GDCRA
    Hi GC,
    Your best bet is probably to convert the code into an 'asynchronous' IPC (inter-process communication) call so that whenever 'data' is present on the channel (i.e. the external script has printed something) you can deal with it. There should be examples and solution articles for asynchronous IPC on the Support website as well as in the documentation.  If you don't want to do that you could set up a while() loop, like while(ipcReadProcess(cid) ... or while(ipcIsAliveProcess(cid) ...
    Best regards,
    Lawrence.
