  3. script to show revision history of given cellview
  • Views 17779
GDCRA
GDCRA over 7 years ago
I was wondering if there is function or skill script that can be run on opened cellview (be it schematic ,layout or symbol). and it will show revision history for given cellview.
Does anyone know such function or script ?
GC
  • skillUser
    skillUser over 7 years ago
    Hi GC,
    Basically 'no' Virtuoso does not have data management built-in but provides hooks to third party tools like Cliosoft SOS, IC Manage, Design Sync and so on, and so you would have to be using a DM system and then you might be able to view the revision history but it would most likely be outside of Virtuoso.  If your question is more about "what has been done to this design since it was opened" then the CDS.log file is really your only report, it is for everything in the session, not per cellview.
    Best regards,
    Lawrence.
    Andrew Beckett over 7 years ago in reply to skillUser
    If you are using an integrated design management tool, you could do:
    cv=geGetEditCellView()
    gspec=gdmCreateSpec(cv~>libName cv~>cellName cv~>viewName ddGetObj(cv~>libName cv~>cellName cv~>viewName "*")~>name "CDBA")
    result=nil
    foreach(info '(6 3 2 1) ; look at gdmhistory documentation to understand the meaning of these numbers (in reverse order)
      if(result then
        result=foreach(mapcar (new existing) gdmhistory(gspec info) result cons(car(new) existing))
      else
        result=gdmhistory(gspec info)
    ; this is just to show what was collected
    pprint(result)
    newline()
    This will output something like:
    (("1.1" "albert" "06/08/2010 17:09:48" "Created the initial design.\n")
    ("1.2" "george" "10/18/2010 09:53:03" "Redesigned input stage.\n")
    ("1.3" "victoria" "06/26/2013 09:03:52" "Improved yield.\n")
  • GDCRA
    GDCRA over 7 years ago in reply to Andrew Beckett
    I am using IC Manage. Is there code to work with IC Manage ?
    GC
    Andrew Beckett over 7 years ago in reply to GDCRA
    Hi GC,
    You should ask IC Manage this question. I'm not sure whether gdmhistory works with their integration and I can't easily test at the moment.
