  3. Displaying all the decimal digits of a floating point n...
  • Views 19008
Displaying all the decimal digits of a floating point number
Mallikarjun032
Mallikarjun032 over 7 years ago
I would like to know if it's possible to display all the decimal digits of a floating point number.
For example, if I set "a=1.23456789", and when I use the expression "a", only 6 decimal digits are displayed, like "1.234567".
Is it possible to display all the decimal digits of a floating point number?
Mallikarjun
    Hi Mallikarjun,
    If you use:
    sstatus(fullPrecision t)
    Then the default print representation of floating point numbers extends to 16 significant digits rather than 7 by default. Note that double precision floating point numbers have just under 16 significant digits (stored as a 53 bit mantissa) so there is no more accuracy than that. You can also use the precision controls with printf (e.g printf("%.16g\n" num) or printf("%8.3f\n" num) - with %g it is the number of significant digits, with %f it's the number of decimal places to the right of the point)
  • Mallikarjun032
    Mallikarjun032 over 7 years ago in reply to Andrew Beckett
    Thanks a lot Andrew.
