  3. How to change a layer in layermap file when stream in
  • Views 19349
wenckey
wenckey over 7 years ago
I want to stream in a layout.
I have the steam in teplate file like below:
runDir "."
library "mylib"
strmFile "cellA.sf"
logFile "cellA.err"
topCell "cellA"
refLibList ""
layerMap "strmlyr.in"
fontMap ""
checkPolygon
case "preserve"
propMap "prop.map"
hierDepth 32
pinAttNum 0
cellMap ""
translateNode
userSkillFile ""
propSeparator ","
attachTechFileOfLib "techlib"
maxCellsInTargetLib 20000
scaleTextHeight 1
viaMap ""
view "layout"
summaryFile "cellA.strmIn.summary"
techRefs ""
objectMap ""
And My layer map file strmlyr.in:
met1 drawing 74 0
met2 drawing 157 0
layer1 drawing 13 0
layer2 drawing 65 0
When stream in the layout, I want to change my met1 drawing 74 0 to met0 drwaing 40 0.
How can I do ?
  • AurelBuche
    AurelBuche over 7 years ago +1
    I am not sure what you mean, The layermap is a text file with explicit translations between GDS layer and how they are understood by cadence in your layout. In your case, you have: met1 drawing 74…
  • AurelBuche
    met1            drawing         74            0
    So this mean the layer identified as 74 in your GDS will be translated as met1 in your cadence view
    If you place the following line in your layermap:
    met0            drawing         40            0
    you are now changing the GDS layer 40 into met0 in Cadence layout view
    If you want to replace the met1 with met0 in your layer map you simply need to change your strmlyr.in file into
    #strmlyr.il
    #Cadence layer    Cadence layer    Stream layer    Stream data
    #name             purpose          number          type
    #met1              drawing          74              0
    #met1 replaced by met0
    met0              drawing          74              0
    met2              drawing          157             0
    layer1            drawing          13              0
    layer2            drawing          65              0
    #end of strmlyr.in
    If you want your met0 to be both layer 40 and 74 replace the met0 line with:
    met0              drawing       40,74           0
  • wenckey
    wenckey over 7 years ago in reply to AurelBuche
    Thanks.
    It works
