  3. Skill languag(beginner level)
  • Replies 16
  • Views 8858
Ayushi Nirmal
Ayushi Nirmal over 7 years ago
Hello All,
I am new to skill language and am trying to substitute a label instead of already existing label in a layout design. Can someone please tell me the problem with my code.
cv=dbOpenCellViewByType("ayushi" "pmc_skr_0p8_por_1" "layout" "" "a")
l=cv~>layerPurposePairs
for(i 0 length(l)-1 if(nth(i l)~>layerName=="IP" then sh=nth(i l)~>shapes f=sh~>theLabel subst('abc 'Cell_Id pmc_skr_0p8_por f )))
dbSave(cv)
On loading the particular program into CIW, i am getting this error -
load "/home/nxf51613/random.il"
*Error* eval: unbound variable - pmc_skr_0p8_por
*Error* load: error while loading file - "/home/nxf51613/random.il" at line 3
I dont understand why pmc_skr_0p8_por is showing as an unbound variable whereas it is being listed in the layout when listed.
Ayushi.
    Andrew Beckett over 7 years ago in reply to Ayushi Nirmal
    Something like this would be a good basis of your code. The Technology label handling is just a suggestion to show what it might look like if you have labels such as "& Technology MyTech180":
    procedure(CCFupdateLabels(@key (cvId geGetEditCellView()) (layer "IP")
            (purpose "drawing"))
        let((lpp Date_Time Technology currentTime)
            currentTime=timeToTm(stringToTime(getCurrentTime()))
            ; Define any regular expressions needed to identify the labels
            Date_Time=pcreCompile("^& Date_Time")
            Technology=pcreCompile("^& Technology")
            ; Find the right layer purpose
            lpp=car(
                exists(LP cvId~>lpps LP~>layerName==layer &&
                    LP~>purpose==purpose)
            foreach(shape lpp~>shapes
                when(shape~>objType=="label"
                    cond(
                        ; Look for date labels - update to current time
                        (pcreExecute(Date_Time shape~>theLabel)
                            shape~>theLabel=
                                sprintf(nil "& Date_Time %04d%02d%02d"
                                    currentTime->tm_year+1900
                                    currentTime->tm_mon+1
                                    currentTime->tm_mday
                        ; Look for technology labels - update to current
                        ; tech lib name
                        (pcreExecute(Technology shape~>theLabel)
                            shape~>theLabel=
                                sprintf(nil "& Technology %s"
                                    techGetTechFile(cvId)~>libName
                        ; Add other condition branches here
            t
  • Ayushi Nirmal
    Ayushi Nirmal over 7 years ago in reply to Andrew Beckett
    Thank you so much for the help but I am facing difficulties in understanding the code. Could you please provide me your Gmail Id and we can communicate better there. Also can you provide me a test bench for the above code since I am not able to execute it.
    No, I'm not going to provide my "gmail" id (or even my Cadence email address) in a public forum. I thought you had some data to run this on yourself? I simply created a bunch of labels on the right layer like this:
    The white labels (in my case) where on layer text/drawing and the blue label on Metal1/drawing (because I didn't have an IP layer in my PDK). I can then put the code above into a file (say  CCFupdateLabels.il) and then do (once):
    load("CCFupdateLabels.il") in the CIW
    After loading, I just do:
    CCFupdateLabels(?layer "text")  ; you could just run CCFupdateLabels() since the layer would be the right layer.
    Then the white & Technology and & Date_Time labels will get updated. The others are left alone.
  • Ayushi Nirmal
    Thank you so much Andrew for the code, it is working perfectly fine. Ok, I will try to understand the code by myself then.
    Ayushi.
    Hi Ayushi,
    I thought the comments in the code were clear enough, but let me describe in pseudo-code how it works:
    Date_Time=CompiledPattern("& Date_Time")
    Technology=CompiledPattern("& Technology")
    lpp=searchForLayerPurpose(layer purpose) # find lpp object for the layer-purpose you want
    foreach shape shapes_on_lpp
      when shape is a label
        if(patternMatch(Date_Time theLabel) then
          theLabel=updateDateTimeLabel()
        else if (patternMatch(Technology theLabel) then
          theLabel=updateTechnologyLabel()
    The cond function is a convenient way of doing if-then-else-if-else-if-else branches. If you're not sure about any of the functions used here, I suggest (if using IC617 or later) you can search in cdsFinder for the function and then press "More Info" to see the full documentation.
  • Ayushi Nirmal
    Thank you so much for above explanation. Yes, sure I will take help from cdsFinder for more information.
    Ayushi.
