  3. string evaluation in a long text
  • Subscribers 150
  • Views 16073
DavidLou
DavidLou over 7 years ago
hello experts,
wondering if someone can help me out while I'm scratching my hair off. say I have a long text string like
   "blabla{a+b}{c}tada{d}..."
I want to replace the contents within {} (and remove {} as well) by evaluated values (if not evaluatable then replace by "?").
{} pair could be anywhere.
how can I use some skill code to do that?
thanks a lot,
David
  • tweeksii
    tweeksii over 7 years ago in reply to DavidLou +1
    You bet! (defun CCSevalBracedExpressionInLongString (longString) (let ((pat (pcreCompile "{(.*)}" (pcreGenCompileOptBits ?ungreedy t)))) (while (pcreExecute pat longString) (let ((value (errset (evalstring…
  • VPrasad
    VPrasad over 7 years ago
    You can use rexCompile and rexReplace to meet your requirement.
    For Example :
                  we have a= "blabla{a+b}{c}tada{d}" then
                 rexCompile( "{[a-zA-Z0-9\\+]*}" )   => t
                 rexReplace( a "(*)" 0) => "blabla(*)(*)tada(*)"
  • DavidLou
    DavidLou over 7 years ago in reply to VPrasad
    thanks VPrasad,
    I could be not clear first hand. I'm looking to evaluate the expression within { } and replace them by the result, so not purely replace by fixed pattern. i.e., if a=1 and b=2, then I should replace {a+b} by 3.
    is that possible?
    thanks,
    David
  • tweeksii
    You bet!
          (let ((value (errset (evalstring (pcreSubstitute "\\1")))))
            (setq longString (pcreReplace pat longString (if value (printself (car value)) "?") 1))))
        longString))
    (let ((a 1)
          (b 2)
          (c "hello")
          (d 'unbound))
      (CCSevalBracedExpressionInLongString "blabla{a+b}{c}tada{d}"))
    => "blabla3\"hello\"tada?"
    Thanks for a fun one. Smile
  • DavidLou
    DavidLou over 7 years ago in reply to tweeksii
    OMG~~~~~~      YOU MADE IT!
