  3. (getCallingFunction) in SKILL++
  • Subscribers 148
  • Views 15565
AurelBuche
AurelBuche over 7 years ago
I would like to define enhanced info, warn, error functions so the name of the calling function is printed at the beginning of the message:
Here is what I've done for info: (same with warn and error)
(defun infox (message @rest args "tg")
  (apply 'info (cons (strcat (or (getCallingFunction) "") ": " message "\n") args)))
It works perfectly fine in SKILL but it does not in SKILL++:
\i toplevel 'il
\p >
\i (defun helloWorld nil (infox "my message"))
\o function helloWorld redefined
\t helloWorld
\p >
\i (helloWorld)
\o helloWorld: my message
\t nil
\p >
\i (defun helloWorld nil (let nil (infox "my message")))
\t helloWorld
\p >
\i (helloWorld)
\t nil
\p >
\i toplevel 'ils
\p ILS->
\w *WARNING* (define): redefining SKILL function helloWorld to be Scheme variable
\t helloWorld
\p ILS->
\i (helloWorld)
\t nil
\p ILS->
\o variable helloWorld redefined
\t helloWorld
\p ILS->
\i (helloWorld)
\o : my message
\t nil
\p ILS->
It seems that the environment defined by the let in SKILL++ is blocking access to the call stack but I do not get why
Any proper solution or workaround would be very welcome as I don't think typing the name of the calling function in every message I write is the best solution
  • mbracht
    mbracht over 7 years ago +1
    Hi, This behaviour is not reproducible for me - I'am always getting name of the calling function. Other that that - why do you redefine the functions in SKILL++ - since plain SKILL and SKILL++ share…
  • mbracht
    Other that that - why do you redefine the functions in SKILL++ - since plain SKILL and SKILL++ share functions that shouldn't be necessary.
    Max
  • AurelBuche
    AurelBuche over 7 years ago in reply to mbracht
    Ok thanks,
    I don't know exactly where I am corrupting my call stack because in a clean setup I don't have this issue but when I autoload my SKILL files it still happen
    It works fine in IC 6.1.8 though
    About the functions definition I know SKILL and SKILL++ can both share their functions but they are not defined the same way so I tried both possibilities to be sure it was not due to that
