  3. rodCreateRect subRectArray loop
  • Views 16117
psill000
psill000 over 7 years ago
I am creating a stdcell pcell base layer cell and I am using the rodCreateRect function.
Is it possible to create a loop for the subRectArray so I can create a double or triple high stdcell without write another procedure. single high works as I want.
double high example of layers to stack
nplus_implant
pplus_implant
pplus_implant
nplus_implant
Paul
  • mbracht
    mbracht over 7 years ago +1
    Hi Paul, I don't think this is possible with rodCreateRect(). Alternatively you might use rodCreatePath() with the ?subRect argument. That lets you define any number of sub pathes - here's an example…
  • mbracht
    mbracht over 7 years ago in reply to psill000 +1
    well you could use "foreach mapcar" to get the list of sublists required for ?subRectArray: ?subRectArray (foreach mapcar layer '("metal1" "metal2" "metal3") (list '?layer layer)) Is this what you…
  • mbracht
    Hi Paul,
    I don't think this is possible with rodCreateRect(). Alternatively you might use rodCreatePath() with the ?subRect argument. That lets you define any number of sub pathes - here's an example:
    (rodCreatePath ?cvId cv ?layer "metal1" ?pts (list 0:0 0:12)
         ?subRect (list
             (list ?layer "via1")
             (list ?layer "via2")
  • psill000
    psill000 over 7 years ago in reply to mbracht
    I can do multiple subRect also, but I was looking for a way to create a loop of the different layers for a two or more high stdcell.
    Example:
    ?subRect list(
                list(?layer "lpp1")
                list(?layer "lpp2")
                list(?layer "lpp3")
                list(?layer "lpp3")
                list(?layer "lpp2")
                list(?layer "lpp1")
  • mbracht
    Is this what you were looking for?
    Max
