  3. Assign connectivity to metals using SKILL
  • Views 18661
Uday Shankar
Uday Shankar over 7 years ago
I am creating a pathSeg(in Layout_XL) using dbCreatePathSeg in SKILL and looking for a SKILL command to assign a "Connectivity" for the created pathSeg shape.
I tried the below option and is not working.
cvid = geGetEditCellView()
path_db = dbCreatePathSeg(cvid "M1" 0:0 1:0 0.1 "truncate" "truncate")
net_db=dbMakeNet(cvid "vdd")
path_db~>net = net_db
Uday
  • mbracht
    mbracht over 7 years ago
    Hi Uday,
    I think in order to get this running in VXL you need to set the SKILL environment variable extractKeepShapeAssignment to true - just put this line in your .cdsenv
    layout extractKeepShapeAssignment boolean t
    and then:
    dbAddFigToNet(path_db net_db)
    By the way - you may as well set this flag/variable in the Layout XL options under the Connectivity tab.
    Max
  • Uday Shankar
    Uday Shankar over 7 years ago in reply to mbracht
    Hi Max,
    Setting the environment variable made no difference to output.
    Below code worked fine:
    selNets= geGetSelSet()
    parentNet = dbMakeNet(cvid "net1")
    parentNet1 = dbMakeNet(cvid "net1" parentNet)
    if(selNets == nil then
                    println("Phase1")
                    abc=dbCreatePath(cvID list("M3" "drawing") '((2 2) (2 4) (2 6)) 2)
                    abc~>lxStickyNet=t
                    dbSetq(abc parentNet1 net)
    else
                    println("Phase2")
                    foreach(selNet selNets
                                    selNet~>lxStickyNet=t
                                    dbSetq(selNet parentNet1 net)
                    );foreach
    );if
    Uday
    Andrew Beckett over 7 years ago in reply to Uday Shankar
    Uday,
    You can't assign a net using:
    or
    You need to use dbAddFigToNet(selNet parentNet1)
    (your variable names are a bit confusing, since selNet is a figure, not a net).
  • mbracht
    mbracht over 7 years ago in reply to mbracht
    Hmmh...it did work for me. Open an empty cell view in VXL and then copy and paste the above code. A path segment labeled "vdd" appears and the net is also visible in the connectivity tab of the "Edit Properties" form.
    Max
