  3. ADEXL Signal and Expression Details from the output nam...
  • Views 15463
ADEXL Signal and Expression Details from the output name
Curtisma
Curtisma over 7 years ago
Is there a way to get the signal or expression details for a given named Maestro output?  I can use the maestro command maeGetResultOutputs to get the names of all the outputs in a result and I can use the ADE-XL and L interface to get to the output objects for the active database using asiGetOutputList.  However when I do that the name property for all the outputs is nil.
As far as I can tell the only way to get the signal or expression details is to use axlOutputsExportToFile and then open the csv file that is exported to extract the output information.  Is there an easier way to do this entirely in SKILL without handling a file?
-Curtis
    Hi Curtis,
    asiGetOutputList is really all there is. The way that the naming works is that if a name is present, that is used. If not, the signal (or the expression) is used as the name.
