  3. Converting a veriloga model to a schematic symbol
  • Views 16715
lbodepu
lbodepu over 7 years ago
Hi ,
I am using a code which is very similar to the schematic to the symbol
procedure(CCSautoCreateSymbol(sourceLib reCreate)
let((libId targetLib cellList sourceView targetView dataTypeView funct1 funct2)
libId = ddGetObj(sourceLib)
targetLib = sourceLib
cellList = libId~>cells
sourceView = "veriloga"
targetView = "symbol"
dataTypeView="schematicSymbol"
foreach(cell cellList
if(member(sourceView cell~>views~>name) then
if( reCreate || !member("symbol" cell~>views~>name) then
schHiViewToView(?libName sourceLib     ?cellName cell~>name      ?viewNameFrom sourceView         ?viewNameTo targetView    ?dataType dataTypeView )
) ;if
) ;if
);foreach
ddReleaseObj(libId)
);let
printf("\nJob Done!\n")
);procedure
But I am not able to automatically close the dialog box Cellview from Cellview.
Is there any command that I have to add to automate it?
Lavanya
    Hi Lavanya,
    I suggest you use schViewToView rather than schHiViewToView (see the documentation for the usage details). This then does not bring up a form.
  • lbodepu
    lbodepu over 7 years ago in reply to Andrew Beckett
    I am not able to use schViewToView because its arguments schVerilogToPinList doesnt seem to work for verilog a.
    Lavanya
    Andrew Beckett over 7 years ago in reply to lbodepu
    Hi Lavanya,
    You need to use ahdlToPinList instead of schVerilogToPinList. Or for generating VerilogA from a pin list you'd use ahdlPinListToveriloga . Not sure why these aren't documented (they should be). This article helps you find the relevant functions: schViewToView: How to find translation functions for different views
  • lbodepu
    Thank you for the help Andrew
