  3. Config View Assignment
  • Views 21285
Curtisma
Curtisma over 7 years ago
Hello:
I have a config view where some of the cells are assigned to Verilog-A views.  I am trying to get a list of the library and cell names of any cells assigned to use a "veriloga" view.  Is there any easy way to do this or a clear example showing how to use the hdb functions to do something similar.  Hopefully, one that is more clear or better written than hdbTraverse.il  Do I need to traverse the whole hierarchy?  I only need the cells whose view is assigned to veriloga, not individual instances.
-Curtis
    Hi Curtis,
    You really need to traverse the hierarchy to collect this information because it's possible that the VerilogA views are bound via a variety of different mechanisms. It could be via cell bindings, instance bindings, occurrence bindings, inherited view lists, or configs within configs - lots of possibilities.
    I wrote some code to traverse config views as part of a schematic tree generation tool (which I wrote before a similar capability was added in the schematic editor as standard). I wrote this in a way that allowed (via SKILL++ objects) to have methods which collected information. The Schematic Tree stuff is in a form on support.cadence.com but I'll post the original "ab" version here, as well as the second code which does exactly what you want and collects the views used - you could then filter that to find the cells with VerilogA views used somewhere in the design hierarchy via the config.
    I'll post the code in two posts to make it easier. The first is the generic schematic tree traversal which handles both view lists and configs (written in LISP style):
    /* abSchTree.il
    Author     A.D.Beckett
    Group      Custom IC, Cadence Design Systems Ltd.
    Machine    SUN
    Date       Oct 30, 1995
    Modified   Nov 07, 2010
    By         A.D.Beckett
    Function to perform the equivalent of the "tree" function
    for schematics
    There are three entry points in this file:
    (abSchTree [optional key arguments])
        Low level entry point - no form. Just uses arguments to define how and
        where the tree gets created
    (abHdbSchTree [optional key arguments])
        where the tree gets created. Similar to abSchTree, but for
        config views.
    (abHiSchTree)
        Form interface to abSchTree and abHdbSchTree.
    Extended to support configs in July 2006, as well as allowing
    output methods to be supplied, so that output can be sent
    elsewhere in different formats.
    SCCS Info: @(#) abSchTree.il 01/13/12.14:08:45 1.9
    *               (abCompareCellName inst1 inst2)                *
    *       Comparison function when sorting the instHeaders       *
    (defun abCompareCellName (inst1 inst2)
      (let (result)
           (forall property '(libName cellName viewName)
                   (equal (setq result
                                (strcmp (dbGet inst1 property)
                                        (dbGet inst2 property))) 0))
           (lessp result 0)))
    *                   (abSchTreeOutputElement                    *
    *              obj indent instInfo lib cell view               *
    *                 boundLib boundCell boundView                 *
    *             displaySwitchedView isStoppingView)              *
    *   Generic function to output an element into the tree. Is    *
    *   passed a whole bunch of information that could be useful   *
    *                    to the output function                    *
    (defgeneric abSchTreeOutputElement
                (obj indent instInfo lib cell view
                nil
    *               (abSchTreeOutputPush obj indent)               *
    * Generic function called whenever the hierarchy is descended  *
    *   in the tree. Allows the output formatter to do something   *
    *    if needed. There is no method for port, so normally it    *
    *                     doesn't do anything.                     *
    (defgeneric abSchTreeOutputPush
                (obj indent)
                nil
    *               (abSchTreeOutputPop obj indent)                *
    * Generic function whenever the hierarchy is ascended. Similar *
    *                   to abSchTreeOutputPush.                    *
    (defgeneric abSchTreeOutputPop
                (obj indent)
                nil
    *                    abSchTreeOutputElement                    *
    *  Method specialized on port - is the normal element output   *
    *                    for the tree utility.                     *
    (defmethod abSchTreeOutputElement
      ((obj port) indent instInfo lib cell view
                  _boundLib _boundCell boundView
                  displaySwitchedView _isStoppingView)
      (let (displayedView formatString)
        (if (and displaySwitchedView boundView)
          (sprintf displayedView " [%s]" boundView)
          (setq displayedView "")
        (sprintf formatString "%%%ds %%s %%s %%s %%s%%s\n"
                 indent)
        (fprintf obj formatString ""
                 lib
                 cell
                 view
                 instInfo
                 displayedView
    *            (abSchTree @key (cellView (geGetEditCellView))             *
    *                (viewList "schematic cmos.sch symbol")                 *
    *                          (stopList "symbol")                          *
    *                             (port poport)                             *
    *                           (displayPins nil)                           *
    *                              (indent 0))                              *
    *                           (useViewSwitching t)                        *
    *                           (libStopList nil))                          *
    * Recursive function to output a "tree" like display from the specified *
    * cellView downwards using the specified view and stop lists. The pins  *
    *  can be displayed as well if desired. The indent is for internal use  *
    *   only and controls the indent level that this cellView's instances   *
    *                            are printed at.                            *
    *     libStopList allows libraries to be filtered - this is a space     *
    * separated string of library names to ignore. Setting useViewSwitching *
    *                to nil means it is suitable for layouts.               *
    (defun abSchTree (@key (cellView (geGetEditCellView))
                          (stopList "symbol")
                          libStopList
                          (port poport)
                          (displayPins nil)
                          (displaySwitchedView nil)
                          (indent 0))
      (let (sortedHeaders count stopAtList isStoppingView
                          switchedView)
           (setq stopAtList (parseString stopList))
           (unless (listp libStopList) (setq libStopList (parseString libStopList)))
           (setq sortedHeaders
                 (sort (dbGetq cellView instHeaders) 'abCompareCellName))
           (foreach header sortedHeaders
                    ; count the number of instances
                    (setq count (length
                                 (if displayPins
                                     ; if we're displaying pins, count them
                                     ; all regardless
                                     (dbGetq header instances)
                                     ; otherwise only count those without
                                     ; purpose pin
                                     (setof inst
                                            (nequal (dbGetq inst purpose) "pin")))))
                    ; when there was at least one
                    ; (so that pins can be filtered out)
                    (when (greaterp count 0)
                      ; Stop if the library is in the stop list
                      (unless (member (dbGetq header libName) libStopList)
                        ; switch views (unless asked not to)
                        (if useViewSwitching
                          ; then
                          (progn
                            (setq switchedView (dbGetAnyInstSwitchMaster
                                                 (car (dbGetq header instances))
                                                 viewList))
                            (setq isStoppingView
                                  (and switchedView
                                       (member (dbGetq switchedView viewName)
                                               stopAtList)))
                          ; else
                          (progn
                            (setq switchedView (dbGetq header master))
                            (setq isStoppingView nil)
                          port
                          indent
                          (sprintf nil "(%d)" count)
                          (dbGetq header cellName)
                          (dbGetq header viewName)
                          displaySwitchedView
                          isStoppingView)
                        ; Recursively expand the hierarchy
                        (when switchedView
                          (unless isStoppingView
                            (abSchTreeOutputPush port indent)
                            (abSchTree ?cellView switchedView
                                       ?viewList viewList
                                       ?stopList stopList
                                       ?libStopList libStopList
                                       ?port port
                                       ?displayPins displayPins
                                       ?displaySwitchedView
                                       displaySwitchedView
                                       ?useViewSwitching useViewSwitching
                                       ?indent (plus indent 2))
                            (abSchTreeOutputPop port indent)
                          ; I did try closing the switched cell, but it
                          ; didn't work properly. Have to live with this,
                          ; I suppose!
           t))
    *  (abHdbSchTree @key libName cellName viewName (port poport)  *
    *         (displayPins nil) (displaySwitchedView nil)          *
    *    (indent 0) (collapseStoppingViews t) (physConfig nil)     *
    *    Similar to abSchTree, but works on config views. As a     *
    *      result, the lib, cell, and view of the config view      *
    *      need to be passed in (as it opens the config). The      *
    *       main difference in arguments is the presence of        *
    *      the collapseStoppingViews argument. Because there       *
    *    may be instance and occurrence bindings in the config,    *
    *   we normally have to descend into every occurence in the    *
    *    hierarchy. The collapseStoppingViews argument is used     *
    *   to only output instances which are at stop points once,    *
    *     with a count - but can be turned off to output every     *
    *  instance regardless. physConfig is to say that this is a    *
    *    physical config view. Only limited support for these.     *
    (defun abHdbSchTree (@key
                          libName
                          cellName
                          viewName
                          (port poport)
                          (displayPins nil)
                          (indent 0)
                          libStopList
                          physConfig
      (let (configId pathVectorStack configBag)
        (setq configBag (hdbCreateConfigBag))
        (setq configId
              (if physConfig
                (hdbOpen libName cellName viewName "r" "CDBA" "physExpand.cfg")
                (hdbOpen libName cellName viewName "r")
        (setq pathVectorStack (hdbCreatePathVectorStack))
        (if configId
          (progn
            (abHdbSchTreeTraverseConfig
              ?port port
              ?displaySwitchedView displaySwitchedView
              ?indent indent
              ?pathVectorStack pathVectorStack
              ?configId configId
              ?configBag configBag
              ?collapseStoppingViews collapseStoppingViews
            (hdbCloseConfigsInBag configBag)
          (error "Could not open config %Y/%Y/%Y\n" libName cellName viewName)
          ) ; if
        ) ; let
      ) ; defun abHdbSchTree
    *                  (abHdbSchTreeTraverseConfig                   *
    * @key (port poport) (displayPins nil) (displaySwitchedView nil) *
    *         (indent 0) pathVectorStack configId configBag          *
    *                   (collapseStoppingViews t))                   *
    *   Given an open config, path vector stack, and a config bag,   *
    *   traverse the config. This is called from abHdbSchTree, but   *
    *    may also be called from abHdbSchTreeTraverseCellView if     *
    *         a config is switched into from another config.         *
    (defun abHdbSchTreeTraverseConfig (@key
                                        (port poport)
                                        (displayPins nil)
                                        (indent 0)
                                        pathVectorStack
                                        configId
                                        configBag
                                        libStopList
      (let (libName cellName viewName pathVector)
        (hdbAddConfigToBag configBag configId)
        ; Find out the cellView associated with the config
        (setq libName (hdbGetTopLibName configId))
        (setq cellName (hdbGetTopCellName configId))
        (setq viewName (hdbGetTopViewName configId))
        ; Create a path vector to manage the hierarchy traversal, and
        ; then push it onto the stack
        (setq pathVector (hdbCreatePathVector configId))
        (hdbPushPathVect pathVectorStack pathVector)
        ; Traverse the cellView
        (abHdbSchTreeTraverseCellView
          ?libName libName
          ?cellName cellName
          ?viewName viewName
          ?port port
          ?indent indent
        ; Cleanup. All the configs will be closed at the top level
        (hdbPopPathVect pathVectorStack)
        (hdbDestroyPathVector pathVector)
        ) ; let
      ) ; defun abHdbSchTreeTraverseConfig
    *                     (abHdbSchTreeTraverseCellView                      *
    *              @key libName cellName viewName (port poport)              *
    *         (displayPins nil) (displaySwitchedView nil) (indent 0)         *
    *          pathVectorStack configBag (collapseStoppingViews t))          *
    *        The function which does all the work for cellViews under        *
    *     configs. This uses pcdb to iterate over the instance masters,      *
    *    and then the instances (it can iterate over both the structural     *
    * instances, plus any "ignored" instances like pins, taps, sheets, etc). *
    *              Recursively descends through the hierarchy.               *
    (defun abHdbSchTreeTraverseCellView (@key
                                          libName
                                          cellName
                                          viewName
                                          (port poport)
                                          (displayPins nil)
                                          (indent 0)
                                          pathVectorStack
                                          configBag
                                          libStopList
      (let (pathVector pcId instMasterGens instMaster instGen inst
                       masterLibName masterCellName masterViewName
                       fixedLib fixedCell fixedView instName bindInfo
                       isStoppingView deferredInfo newInfo instInfo
                       expandMasterGens deferredCount)
        (setq pathVector (hdbGetPathVectorStackTop pathVectorStack))
        (setq pcId (pcdbOpen libName cellName viewName "r"))
        (when pcId
          ; Create a list of one or two inst master generators, depending
          ; on whether pins (i.e. "ignored" instances) are traversed. A
          ; second list is created indicating whether expansion should
          ; happen or not for that masterGen - it shouldn't happen for
          ; the "ignored" instances.
          (setq instMasterGens
                `(,(pcdbGetInstMasterGen pcId)
                   ,@(and displayPins (list (pcdbGetIgnoredInstMasterGen pcId)))
          (setq expandMasterGens `(t ,@(and displayPins (list nil))))
          ; Loop over the one or two inst master generators
          (foreach
            (instMasterGen expandMasterGen) instMasterGens expandMasterGens
            (setq instMaster (pcdbNextInstMaster instMasterGen))
            (while instMaster
                   ; Gather information about the master
                   (setq masterLibName (pcdbInstMasterLib instMaster))
                   (setq masterCellName (pcdbInstMasterCell instMaster))
                   (setq masterViewName (pcdbInstMasterView instMaster))
                   (setq fixedLib (pcdbInstMasterLibFixed instMaster))
                   (setq fixedCell (pcdbInstMasterCellFixed instMaster))
                   (setq fixedView (pcdbInstMasterViewFixed instMaster))
                   (unless (member masterLibName libStopList)
                     ; Now traverse the instances
                     (setq instGen (pcdbGetInstGen instMaster))
                     (setq inst (pcdbNextInst instGen))
                     (while inst
                            (setq instName (pcdbInstName inst))
                            (setq bindInfo
                                  (and expandMasterGen
                                       (hdbBind
                                         pathVector
                                         masterLibName
                                         masterCellName
                                         masterViewName
                                         instName
                                         fixedLib
                                         fixedCell
                                         fixedView
                                         t
                            (setq boundLib (car bindInfo))
                            (setq boundCell (cadr bindInfo))
                            (setq boundView (caddr bindInfo))
                            ; Only push if the view was bound
                            (if (and boundLib boundCell boundView)
                              (progn
                                (hdbPushCell
                                  pathVector instName boundLib boundCell boundView)
                                (setq isStoppingView (hdbIsAtStopPoint pathVector))
                              ; Otherwise pretend it is a stopping view to prevent
                              ; hierarchy expansion
                              (setq isStoppingView t)
                            (when collapseStoppingViews
                              ; This is a collection of data used to see if
                              ; this instances is the same as the deferred instance
                              (setq newInfo
                                    (list
                                      instName
                                      boundLib boundCell boundView))
                              ; Output the deferred instance information if
                              ; this is either not a stopping view, or it
                              ; is different from the deferred instance
                              (when
                                (and
                                  (or (null isStoppingView)
                                      (nequal (cdr newInfo) (cdr deferredInfo)))
                                  deferredInfo)
                                (if (greaterp deferredCount 1)
                                  (sprintf instInfo "(%d)" deferredCount)
                                  (setq instInfo (car deferredInfo)))
                                  port
                                  indent
                                  instInfo
                                  (nth 1 deferredInfo)
                                  (nth 2 deferredInfo)
                                  (nth 3 deferredInfo)
                                  (nth 4 deferredInfo)
                                  (nth 5 deferredInfo)
                                  (nth 6 deferredInfo)
                                  displaySwitchedView
                                  t
                                ) ; when
                              ; Now either update the count, or record the
                              ; deferred instance, or discard the current data
                              ; about the deferred instance
                              (cond
                                ((and isStoppingView
                                      (equal (cdr newInfo) (cdr deferredInfo)))
                                 (postincrement deferredCount))
                                (isStoppingView
                                  (setq deferredInfo newInfo)
                                  (setq deferredCount 1)
                                (t
                                  (setq deferredInfo nil)
                                ) ; cond
                              ) ; when
                            ; Output normally if not collapsing, or this is
                            ; not a stopping view
                            (unless (and collapseStoppingViews isStoppingView)
                                port
                                indent
                                instName
                                masterLibName
                                masterCellName
                                masterViewName
                                boundLib
                                boundCell
                                boundView
                                displaySwitchedView
                                isStoppingView
                              ) ; unless
                            ; Now descend if necessary
                              (if (hdbIsConfig boundLib boundCell boundView)
                                ; If a sub-config, traverse that
                                (let (configId)
                                  (setq configId
                                        (hdbOpen boundLib boundCell boundView "r"))
                                    ?port port
                                    ?configId configId
                                ; Otherwise traverse the bound cellView
                                  ?libName boundLib
                                  ?cellName boundCell
                                  ?viewName boundView
                                  ?port port
                                ) ; if
                              ) ; unless isStoppingView
                            ; Pop back up again
                            (when (and boundLib boundCell boundView)
                              (hdbPopCell pathVector)
                            ) ; while inst
                     ; Output any deferred instances from collapsing that
                     ; are left over before moving onto the next master
                     (when deferredInfo
                         port
                         indent
                         instInfo
                         displaySwitchedView
                         t
                     ) ; unless member libStopList
                   ; Move to next instance master
                   ) ; while instMaster
            ) ; foreach instMasterGen
          (pcdbClose pcId)
          ) ; when
        ) ; let
      ) ; defun
    *                   (abCreateHiSchTreeForm)                    *
    *       Create the form for the schematic tree function        *
    (defun abCreateHiSchTreeForm ()
      (let (topOrCurrent viewList stopList displayPins displaySwitchedView
                         libStopList)
           (setq topOrCurrent
                 (hiCreateRadioField
                  ?name 'topOrCurrent
                  ?prompt "Starting cell"
                  ?choices '("current" "top")))
           (setq viewList
                 (hiCreateStringField
                  ?name 'viewList
                  ?prompt "View list"
                  ?value "schematic cmos.sch symbol"))
           (setq stopList
                  ?name 'stopList
                  ?prompt "Stop list"
                  ?value "symbol"))
           (setq libStopList
                  ?name 'libStopList
                  ?prompt "Ignore libraries"
                  ?value ""))
           (setq displayPins
                 (hiCreateBooleanButton
                  ?name 'displayPins
                  ?buttonText "Display pins"
                  ?value nil))
           (setq displaySwitchedView
                  ?name 'displaySwitchedView
                  ?buttonText "Display view used"
                  ?value nil))
           (setq abHiSchTreeForm
                 (hiCreateAppForm
                  ?name 'abHiSchTreeForm
                  ?formTitle "Schematic Tree"
                  ?callback 'abHiSchTreeCB
                  ?fields (list
                           topOrCurrent viewList stopList libStopList
                           displayPins displaySwitchedView)))
           abHiSchTreeForm))
    *                     (abHiSchTreeCB form)                     *
    *            Callback for the schematic tree form.             *
    *      Opens the file, outputs the header information and      *
    *     then calls abSchTree to recursively descend down the     *
    *                          hierarchy.                          *
    *         Then the output file is viewed and deleted.          *
    (defun abHiSchTreeCB (form)
      (let (cellView oport fileName)
           (setq cellView
                 (if (equal (getq (getq form topOrCurrent) value) "top")
                     (geGetTopLevelCellView (getq form treeWindow))
                     (geGetEditCellView (getq form treeWindow))))
           (if cellView
               (progn
                (setq oport (outfile (setq fileName
                                           (makeTempFileName "/tmp/schTree"))))
                (if oport
                    (progn
                     (fprintf oport "%40s\n","Design Hierarchy")
                     (fprintf oport
                      "*******************************************************\n")
                     (fprintf oport "Library : %s\n" (dbGetq cellView libName))
                     (fprintf oport "Cell    : %s\n" (dbGetq cellView cellName))
                     (fprintf oport "View    : %s\n" (dbGetq cellView viewName))
                     (fprintf oport "Option  : %s to bottom\n"
                              (getq (getq form topOrCurrent) value))
                     (fprintf oport
                      "*******************************************************\n\n"
                     (abSchTree ?cellView cellView
                                ?viewList (getq (getq form viewList) value)
                                ?stopList (getq (getq form stopList) value)
                                ?libStopList (getq (getq form libStopList) value)
                                ?displayPins (getq (getq form displayPins) value)
                                    (getq (getq form displaySwitchedView) value)
                                ?port oport
                     (close oport)
                     (view fileName nil "Tree")
                     (deleteFile fileName)
                    (error "Couldn't open output file"))
               (error "Couldn't find cellView"))
    *                    (abCreateHiHdbSchTreeForm)                     *
    * Since the form fields for expanding a config view are pretty much *
    * completely different from a normal view, create a separate form.  *
    *               Easier than having the form dynamic.                *
    (defun abCreateHiHdbSchTreeForm ()
      (let (displayPins displaySwitchedView collapseStoppingViews libStopList)
           (setq displayPins
                  ?name 'displayPins
                  ?value nil))
                  ?value nil))
           (setq collapseStoppingViews
                  ?name 'collapseStoppingViews
                  ?buttonText "Collapse stopping views"
                  ?value t))
           (setq libStopList
                   ?name 'libStopList
                   ?value ""
           (hiCreateAppForm
             ?name 'abHiHdbSchTreeForm
                  ?formTitle "Schematic Tree from config"
                  ?callback 'abHiHdbSchTreeCB
                  ?fields (list
                           displayPins
                           displaySwitchedView
                           libStopList))
           ) ; let
      ) ; defun
    *                    (abHiHdbSchTreeCB form)                    *
    *   Form callback for config tree expansion. Opens the file,    *
    * writes out the header, and then calls the expansion function. *
    *       Then closes the file and displays it in a window.       *
    (defun abHiHdbSchTreeCB (form)
      (let (config oport fileName)
        (setq config (getq form config))
        (if oport
          (progn
            (fprintf oport
            (fprintf oport "Library     : %s\n" (hdbGetLibName config))
            (fprintf oport "Cell        : %s\n" (hdbGetCellName config))
            (fprintf oport "View        : %s\n" (hdbGetViewName config))
            (fprintf oport "Top Library : %s\n" (hdbGetTopLibName config))
            (fprintf oport "Top Cell    : %s\n" (hdbGetTopCellName config))
            (fprintf oport "Top View    : %s\n" (hdbGetTopViewName config))
            (fprintf oport
            (abHdbSchTree
              ?libName (hdbGetLibName config)
              ?cellName (hdbGetCellName config)
              ?viewName (hdbGetViewName config)
              ?displaySwitchedView (getq (getq form displaySwitchedView) value)
              ?collapseStoppingViews (getq (getq form collapseStoppingViews) value)
              ?port oport
            (close oport)
        ) ; let
      ) ; procedure
    *                        (abHiSchTree)                         *
    *        Display a form controlling the tree generation        *
    (defun abHiSchTree ()
      (let (wid config)
        (setq wid (hiGetCurrentWindow))
        (setq config (deGetConfigId wid))
        (if config
          ; then
          (progn
            ; create the form if it doesn't exist
            (unless (and (boundp 'abHiHdbSchTreeForm) abHiHdbSchTreeForm)
              (abCreateHiHdbSchTreeForm))
            (putpropq abHiHdbSchTreeForm config config)
            (hiDisplayForm abHiHdbSchTreeForm)
          ; else
          (progn
            (unless (and (boundp 'abHiSchTreeForm) abHiSchTreeForm)
              (abCreateHiSchTreeForm))
            ; store the window on the form so that it will always use the window
            ; that was current when the command was invoked
            (putpropq abHiSchTreeForm wid treeWindow)
            (hiDisplayForm abHiSchTreeForm)
          ) ; if
        ) ; let
      ) ; defun
    Andrew Beckett over 7 years ago in reply to Andrew Beckett
    The second (written in C-style because I thought a colleagues was going to have to modify it) is the code that uses the abSchTree.il code to collect the views used:
    /* abCollectCellViewsInConfig.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 07, 2019
    Modified
    By
    Uses abSchTree.il to collect information about non-stopping
    views in a design hierarchy. Can be passed a schematic view
    and a viewList and stopList, or a config view.
    e.g.
    abCollectCellViewsInConfig("worklib" "top" "config")
    returns:
    (("worklib" "comparator" "verilogams")
        ("worklib" "samplehold" "verilogams")
        ("diglib" "sareg" "module")
        ("worklib" "daconv" "verilogams")
        ("diglib" "vhdl_clock" "vhdl_behavioral")
        ("worklib" "signalSrc" "verilogams")
        ("worklib" "top" "schematic")
        ("worklib" "myreg" "behavioral")
    SCCS Info: @(#) abCollectCellViewsInConfig.il 02/07/19.16:44:01 1.1
    ; A class for holding the information during abSchTree,
    ; and for collecting the cellView information
    defclass(abCollectCellViewsSchTreeClass ()
       (cellViewTable @initarg cellViewTable)
    *   A method to simply collect the non-stopping views in the   *
    *  design hierarchy - called each time a bound view is found   *
    *         when abSchTree is traversing teh hierarchy.          *
    defmethod(abSchTreeOutputElement
            ((obj abCollectCellViewsSchTreeClass) _indent _instInfo _lib _cell
                _view boundLib boundCell boundView
                _displaySwitchedView isStoppingView)
        ; Record the usage of this cellView
        unless(isStoppingView ||
                obj->cellViewTable[list(boundLib boundCell boundView)]
            obj->cellViewTable[list(boundLib boundCell boundView)]= t
    *        abCollectCellViewsInConfig(libName cellName viewName        *
    *  @key (viewList "schematic cmos.csh symbol") (stopList "symbol"))  *
    *    Function to traverse the design hierarchy using abSchTree or    *
    * abHdbSchTree, and return a list of lists of lib/cell/views used in *
    *             the design (not including stopping views)              *
    procedure(abCollectCellViewsInConfig(libName cellName viewName
        let((obj lcv config)
        ; Create the object which will be used in lieu of a port in
        ; abSchTree/abHdbSchTree
        obj=makeInstance(
            'abCollectCellViewsSchTreeClass
            ?cellViewTable makeTable('cellViews nil)
        ; Open the config - if indeed it was a config passed in
        config=
            hdbIsConfig(libName cellName viewName) &&
            hdbOpen(libName cellName viewName "r")
        if(config then
            ; Record top cell in cellView table
            lcv=list(
                    hdbGetTopLibName(config)
                    hdbGetTopCellName(config)
                    hdbGetTopViewName(config)
            obj->cellViewTable[lcv]=t
            abHdbSchTree(
                ?libName libName
                ?cellName cellName
                ?viewName viewName
                ?displaySwitchedView t
                ?port obj
            hdbClose(config)
        else
            ; else it's a normal design
            lcv=list(libName cellName viewName)
            abSchTree(
                ?cellView dbOpenCellViewByType(libName cellName viewName)
                ?viewList viewList
                ?stopList stopList
                ?port obj
        ; Return the cellViews used in the design
        obj->cellViewTable->?
  • Curtisma
    Curtisma over 7 years ago in reply to Andrew Beckett
    Excellent!  The second one looks like it will do the trick perfectly.  Thanks!  I'll try it out here shortly.
    -Curtis
    Andrew Beckett over 7 years ago in reply to Curtisma
    Just noticed that the formatting of my code formatter is a bit strange with the hdb functions - it's a bit stupid and doesn't see the "h" before the "db". Still, doesn't stop it working...
