  3. What setting will impact atof() output
  • Replies 8
  • Views 18988
wenckey
wenckey over 7 years ago
I run atof("9.12") in my CIW, it will return 9.11999999999999
And I run virtuoso -nocdsinit, it will return 9.12
What will impact that?
  • skillUser
    skillUser over 7 years ago +1
    Hi, This setting controls the display precision: sstatus(fullPrecision t) you can test the setting using status(fullPrecision). The documentation states this: If t, unformatted print functions…
  • skillUser
    skillUser over 7 years ago in reply to wenckey +1
    sstatus(fullPrecision nil) atof("9.12") => 9.12 You didn't state what fullPrecision is currently set to, but I expect that it was set to 't', so setting it to 'nil' should give you the above result. …
  • skillUser
     If t, unformatted print functions (print, println, printlev) print floating point numbers in full precision (usually 16 digits); otherwise, the default is about 7 digits of precision.
    Best regards,
    Lawrence.
  • wenckey
    wenckey over 7 years ago in reply to skillUser
    Thanks a lot Lawrence!!
    What if I want it to return "9.12"?
  • skillUser
    atof("9.12")
    => 9.12
    Lawrence.
  • wenckey
    Works well.
    Thanks a lot!~
  • psill000
    psill000 over 7 years ago in reply to skillUser
    I was working on a script that compared coordinates and the print out showed the coords were the same but, if i did a minus of the two coords I would not get zero. I would get 1e-18.
    Does the sstatus(fullPrecision nil) fix this problem?
    Andrew Beckett over 7 years ago in reply to psill000
    No, it won't. That simply means that the default print representation when numbers are printed in the CIW (e.g using println) will show 16 digits rather than 7. The storage of the numbers is unaffected.
    If the numbers both come from the database then they would be exactly the same (the same rounding error for both) - it's only if they've been computed differently. You may need to subtract them and check if the difference is less than (say) a tenth of the database unit (so if DBUperUU is 1000, your database resolution is 0.001 um). So do abs(x1-x2)<0.0001 rather than using ==.
  • skillUser
    skillUser over 7 years ago in reply to psill000
    I'm not sure, but as Andrew has repeatedly stated on this forum, regardless of the language (SKILL, Python, C etc.) one should not perform comparisons of floating point numbers the way that you might for strings or integers.
    Try using the nearlyEqual() function to check for equality within a tolerance.
  • psill000
    Thanks Andrew and skillUser for the info
