  3. Plotting from ADE XL saved state
  • Subscribers 150
  • Views 18743
wgtkan
wgtkan over 7 years ago
I am using Cadence Virtuoso Version IC6.1.8-64b.500.1
When replotting a saved state, I get the following error:
WARNING (ADE-1065): No simulation results are available.
ERROR (WIA-1175): Cannot plot waveform signals because no waveform data is available for plotting.
One of the possible reasons can be that 'Save' check box for these signals are not selected in the Outputs Setup pane. Ensure that these check boxes are selected before you run the simulation.
In ADE XL Data view assistant, I RMB desired history > Load Setup to Active and also view result but I keep getting the above error.
Do I have to re-simulate the saved state each time I want to plot the saved waveforms? I am attaching the ADE XL output panel showing the results.
    No, you should be able to plot after doing a "View Results". Please contact customer support so that we can diagnose what is going wrong.
