  3. getting an unknown error while using abeLayerXor in lay...
  • Views 15471
getting an unknown error while using abeLayerXor in layout
RAGHU2634
RAGHU2634 over 7 years ago
I am trying to generate a layer in the regions of (don't overlap b/w two layers) .This are the steps i followed . This is giving an error saying
*Error* abeLayerXor: First layer not correctly specified - nil
Please let me know the issue
tf=techGetTechFile(geGetEditCellView())
tf1=techFindLayer(tf 12)
tf2=techFindLayer(tf 15)
tf3=techFindLayer(tf 18)
tf4=techFindLayer(tf 1090)
tf5=techFindLayer(tf 1091)
tf6=techFindLayer(tf 1092)
tf7=techFindLayer(tf 1093)
tf8=techFindLayer(tf 1117)
tf9=techFindLayer(tf 1118)
tf10=techFindLayer(tf 1130)
tf11=techFindLayer(tf 236)
tf12=techFindLayer(tf 59)
abeInit(geGetEditCellView())
abeLayerXor(tf1 tf11 tf12)
Raghu
    Andrew Beckett over 7 years ago +1
    The abeLayerXor does not accept technology file layer representations. It needs an "abe" layer object - as produced by abeNewLayer, abeLayerFromCellView, abeLayerFromShapes or in fact from any of the other…
  • RAGHU2634
    RAGHU2634 over 7 years ago in reply to Andrew Beckett +1
    techFindLayer works with numebrs too . Thanks andrew. I got it now
    The abeLayerXor does not accept technology file layer representations. It needs an "abe" layer object - as produced by abeNewLayer, abeLayerFromCellView, abeLayerFromShapes or in fact from any of the other abe layer functions. So something like:
    abe1=abeLayerFromCellView(tf1~>name)
    abe11=abeLayerFromCellView(tf11~>name)
    abeOut=abeNewLayer()
    abeLayerXor(abe1 abe11 abeOut)
    abeLayerToCellView(abeOut tf12~>name)
    is probably what you're trying to do. Not sure why you're doing everything with layer numbers - the abe functions expect layer names (hence the ~>name that I use above).
  • RAGHU2634
