  3. Callback writing
  • Subscribers 148
  • Views 7324
Callback writing
FormerMember
FormerMember over 7 years ago
Hi all,
How can I get the cellName of the cell that I modify a parameter into an edit property from ?
I found for the libName:
((cdfgData~>id)~>lib)~>name
or
((cdfgData->id)->lib)->name
or
cdfgData->id->lib->name
but not for the cellName
thanks for your help,
Olivier
    Olivier,
    The same could in theory be done with cdfgData->id->name but this is dangerous (for both cell name and lib name). The issue is that if you want to call CDF callbacks procedurally, you may then work with the instance CDF rather than the cell CDF, and the ->id points at the instance object rather than the cell object.
    I would probably do:
    libName = cdfgData->id->libName || cdfgData->id->lib->name
    cellName = cdfgData->id->cellName || cdfgData->id->name
    That means it would first try looking at the libName and cellName attributes on an instance object (which would work if the cdfgData is an instance CDF) and then the appropriate attributes if it's a cell object from cell CDF.
  • FormerMember
    FormerMember over 7 years ago in reply to Andrew Beckett
    Thank you Andrew,
    Work fine !
