  3. SKILL command to read category files from disc
  • Views 16061
TeeBro
TeeBro over 7 years ago
Hi All,
I'm writing some SKILL code to perform some statistics on cells that are in various categories.  Basically, I generate lists of cells in these categories.  Once I run the script it seems that subsequent calls to the script result in the exact same list even though I have confirmed that the category has changed.  It seems as if it's using a category list from memory and not reading it directly from the disc. If I quit ICFB and restart I get the current category contents as expected.  I have tried to close data, etc and nothing seems to work.  I'm just using the ddCatFindCat and ddCatGetCatMembers functions. Does anyone have any ideas on what I could try?
Best Regards,
TeeBro
    Please provide which version of the tools you're using - i.e. what getVersion(t) outputs, plus ideally the code you're using.
    You refer to ICFB which would imply IC5141, but that may just be a naming convention in your organisation.
  • TeeBro
    Sorry, I should have put that in the original post.  getVersion() yields --> @(#)$CDS: virtuoso version 6.1.7-64b 12/16/2018 07:36 (sjfhw317) $
    Below is the procedure I'm using.
    procedure( pestGetCellList( libName cat )
       let( (catCellList catID catMemList)
          catCellList = nil
          catID = ddCatFindCat( ddGetObj( libName ) cat "r" )
          if( catID
             then
                catMemList = ddCatGetCatMembers( catID )
                if( catMemList
                   then
                      foreach( item catMemList
                         if( cadr(item) == "cell"
                            then
                               catCellList = cons( car(item) catCellList )
                         ); if
                      ); foreach
                ); if
          ); if
          catCellList = sort( catCellList nil )
       ); let
    ); procedure
    Andrew Beckett over 7 years ago in reply to TeeBro
    Add a call:
    ddCatRefresh(catID)
    on the line after ddCatFindCat. That will cause it to refresh from disk if needed, and will solve your problem.
  • TeeBro
    TeeBro over 7 years ago in reply to Andrew Beckett
    I thought I had looked at the documentation but apparently not close enough.  Sorry for not paying closer attention.  Thanks for the help!!
