  3. Popup message in GUI for mouse-hovering
  • Views 16997
Mallikarjun032
Mallikarjun032 over 7 years ago
Please let me know the function to be used to display a popup message on mouse-hovering over a field in a GUI window.
Mallikarjun
  • skillUser
    skillUser over 7 years ago
    Hi Mallikarjun,
    These are two quite different things. The hover-over pop-up is a tooltip which you can specify for the various form fields, toolbar buttons, and menu items - look up hiToolTip in the documentation and you should be able to see how it is done.  Example from the docs:
    myStringField=hiCreateStringField(?name 'myStringField)
    hiFormHandle->myStringField->hiToolTip="description for myStringField"
    For a toolbar or menu item:
    hiCreateAction(
    ?name s_name
    [ ?callback t_callback ]
    [ ?icon g_icon ]
    [ ?iconText t_iconText ]
    [ ?toolTip t_tooltip ]
    ?enabled g_enabled ]
    [ ?checkable g_checkable ]
    [ ?checked g_checked ]
    [ ?defAction g_defaultAction ]
    [ ?actionList l_actionList ]
    [ ?statusTip t_statusTip ]
    [ ?useNameForIconText g_useNameForIconText ]
    => o_action
    Description
    Creates an action for a toolbar or menu. An action is a toolbar or menu item that, when clicked, triggers a callback....
    For a general pop-up feedback, warning, message, error etc:
    hiDisplayAppDBox(
    ?name s_dboxHandle
    [ ?dboxBanner t_dboxBanner ]
    [ ?dboxText t_dboxText ]
    [ ?callback g_callback ]
    [ ?dialogType x_dialogType ]
    [ ?dialogStyle s_dialogStyle ]
    [ ?buttonLayout s_buttonLayout ]
    [ ?buttons g_buttons ]
    [ ?dontPopdowns g_dontPopdowns ]
    [ ?defaultButton x_defaultButton ]
    [ ?location l_location ]
    [ ?help g_help ]
    => t / nil / cancel
    Description
    Creates and displays a dialog box....
    Hopefully this helps you?
    Best regards,
    Lawrence.
  • Mallikarjun032
    Mallikarjun032 over 7 years ago in reply to skillUser
    This is exactly what I was looking for.
    Thanks a lot Lawrence.
