  3. Creating PCells with rounded shapes
  • Views 16926
Miguel V
Miguel V over 7 years ago
I'm trying to create a PCell with rounded or curved shapes.  I know how to create rectangles and polygons using the rodCreateRect() and rodCreatePolygon() methods, but I wanted to know if there is an easier way to create a ROD object with curves, instead of using rodCreatePolygon() with a list of dozens or hundreds of points.
Miguel
  • skillUser
    skillUser over 7 years ago
    Hi Miguel,
    As far as I know the ROD functionality does not extend to non-rectlinear shapes.  The following functions are probably what you need:
    dbCreateEllipse(
    d_cellView
    txl_layerPurpose
    l_bBox
    => d_ellipse / nil
    Creates an ellipse.
    dbCreateArc(
    d_cellView
    txl_layerPurpose
    l_ellipse_bBox
    l_arc_bBox
    => d_arc / nil
    Creates an arc.
    There are also 'donut' shapes. Outside of these I don't know of other curved shapes you can create.
    Hope this helps!
    Lawrence.
  • skillUser
    Also there are these two functions that might help, after you have created the ellipse or donut: dbConvertEllipseToPolygon( d_ellipse x_nSides ),  dbConvertDonutToPolygon( d_donut x_nSides )
  • Miguel V
    Miguel V over 7 years ago in reply to skillUser
    Hi Lawrence,
    Thanks for the response.  I actually found another way.  If I create a polygon by drawing it out, I can create it as a ROD object.  Then once I have all of the pieces I need, I can merge them together and then I have my finalized ROD object with curved features.
    Miguel
