  3. moveOrigin does not work
  • Views 15152
soldier89757
soldier89757 over 7 years ago
I've tried making the origin of the rectangle stretchable by giving 't' to ?moveOrigin in the function rodAssignHandleToParameter but I failed. I succeeded in creating the rectangle and making it stretchable but I can not move the origin of the rectangle. Can anyone tell me why?
Here is my code:
pcDefinePcell(
     list(ddGetObj( "test_lib") "test_pcell" "layout")
     (Metal_W  0.23)
     (Metal_L    0.6)
     (Met1     "METAL1")
     let(()
       Metal=rodCreateRect(
          ?layer   Met1
         ?width   Metal_W
         ?length  Metal_L
      rodAssignHandleToParameter(
          ?Parameter "Metal_L"
          ?rodObj   Metal
          ?handleName list("upperCenter" "lowerCenter")
          ?displayName "Metal_L"
          ?stretchDir "y"
          ?stretchType "relative"
          ?moveOrigin t
          ?updateIncrement    0.005
Regards
John
    Hi John,
    Other than a few typos in the code above (I assume you can't have cut-and-paste it into the forum, because it doesn't work as-is), it works OK. If you have ?moveOrigin nil, then stretching the bottom stretch handle causes the top edge to move up or down, rather than the bottom edge moving up or down. If it is t, then the bottom edge correctly moves (in essence the origin of the shape changes.
    Perhaps you've misunderstood what it's supposed to do? Try setting ?moveOrigin nil and observe the difference in behaviour...
  • soldier89757
    soldier89757 over 7 years ago in reply to Andrew Beckett
    I'm sorry that I've just published wrong codes. The code above is not the one with problem and I have already solved the problem. Thanks for your reply.
    Regards
    Yblin
