  3. get the overlap area of adjacent metals in single hiera...
  • Subscribers 152
  • Views 20357
get the overlap area of adjacent metals in single hierarchy
naresh9005
naresh9005 over 7 years ago
Hi
we are trying to find the overlapping area of adjacent metals(i.e metal1 to metal2, and metal2 to metal3 and so on ) in a single hierarchy.
we are using "dbLayerStraddl()"  function but it is creating a new shape over the first input layer list. but we required the only common area between the two layers.
please help with this problem .
procedure(metalOverlap()
prog( ()
cv=geGetEditCellView()
layer1=list()
layer2=list()
foreach(a cv~>shapes
when(a~>layerName == "MET2"
layer1=cons(a layer1)
when(a~>layerName == "MET3"
layer2=cons(a layer2)
ov=dbLayerStraddl(cv "POLY" layer1 layer2)
hiSetBindKey("Layout" "ShiftCtrl<Key>q" "metalOverlap()")
  • RK56
    RK56 over 7 years ago
    You can try with Advanced Boolean engine functions which have far better outcome. You can control which hierarchy layer you need to process. Check abeLayerFromCellView()
    -Ramakrishnan
  • naresh9005
    naresh9005 over 7 years ago in reply to RK56
    Thank you for your replay,
    our layout cell view has only one hierarchy, but we want to get the overlapping area with coordinates, could you help me with more details?
  • Kevin Earls
    Kevin Earls over 7 years ago
    I will give you some ideas with the following. It doesn't handle metal in vias or other non-metal shapes.
    ;get met1 shapes
    met1list = list() (foreach shape (setof s dbGetOverlaps(cellView cellView~>bBox) car(s~>lpp)=="METAL1") met1list = cons(shape met1list))
    ;get met2 shapes
    met2list = list() (foreach shape (setof s dbGetOverlaps(cellView cellView~>bBox) car(s~>lpp)=="METAL2") met2list = cons(shape met2list))
    ;create scratchcell for dbLayerAnd - you can use the existing cellView if it is editable but you
    ; have to keep track of the created shapes and remove them. Using a scratchcell is easier.
    scratchcell = dbOpenCellViewByType(cellLib cellName "layout_scratch" "maskLayout" "s")
    ; find overlaps and create a TEXT layer for each overlap
    newlayers = dbLayerAnd(scratchcell list("TEXT" "drawing") met1list met2list)
    (foreach shape newlayers
        (printf "%L\n" shape~>bBox)
    ;delete scratch cell
    ddDeleteObj(ddGetObj(scratchcell~>libName scratchcell~>cellName scratchcell~>viewName))
  • RK56
    RK56 over 7 years ago in reply to naresh9005
    Try this to implement using ABE. I copied this script from cadence documentation and modified
    abeInit( geGetEditCellView() )
    M1 = abeLayerFromCellView( "Metal1" ?startLevel 0 ?stopLevel 1 )
    M2 = abeLayerFromCellView( "Metal2" ?purpose "drawing" ?startLevel 0 ?stopLevel 1)
    overlapLayer = abeNewLayer()
    abeLayerAnd( M1 M2 overlapLayer)
    abeLayerToCellView( overlapLayer "marker" ?purpose "error" )
    abeDone()
    You can iterate over the overlapLayer and get all shapes coordinates. Modify the layer names as per your need.
    -Ramakrishnan
  • Saravanan PK
    Saravanan PK over 6 years ago in reply to RK56
    Hi Ramakrishnan,
    what will be the case if I want to find the overlap of the same metals? above code works fine, if both metals are different.
    Saravanan.
    Andrew Beckett over 6 years ago in reply to Saravanan PK
    There's no capability to do a self-and operation with the abeLayer functions - there's some discussion of this in an internal change request (CCR 1522996) but that was just a question to R&D, not an enhancement.
    Normally you'd use a physical verification tool to do this - they typically offer a means of doing a self-and on unmerged layers. Diva and Assura support this via a single layer input to geomAnd, and PVS supports it by providing the same (unmerged) input data as both inputs to the and command in the PVS rule language. Other physical verification tools are available ;-)
    So I'd say the answer is to write a short physical verification rule deck to generate the data you need.
