  3. Maintaining two exclusive lists
  • Replies 9
  • Subscribers 148
  • Views 18159
RK56
RK56 over 7 years ago
I have a GUI with two list boxes. I want to maintain the list box content exclusive of each other. The list box contents are not unique. I want to move selected items to other box and remove from the source. I have implemented the move call back as follows. Since I have used member function, not able to retain duplicate values. Is there any better way of doing?
;;scrField and dstField are the list box field
procedure(moveBin(scrField dstField)
let((scrList dstList)
    scrList = hiGetListBoxValue(scrField)
    dstList = dstField->choices
    foreach(ele scrList
        dstList = cons(ele dstList)
    dstField->choices = dstList
    scrList = setof(x scrField->choices !member(x dstList))
    scrField->choices = scrList
Ramakrishnan
    I'm not sure I quite get what you're asking (I can guess, but I might be guessing wrong). Perhaps a picture of what the form looks like, what it does now and what you're expecting it to do?
  • RK56
    RK56 over 7 years ago in reply to Andrew Beckett
    Here is a picture of my GUI. I want to move selected elements back and forth from pin list listBoxField to selection bin listBoxField. The above procedure is the callback implementation of move buttons. I swap scrField and dstField to move left to right and vice versa. Things works but when there are duplicate entries in the listBox, the above callback is not able to handle and maintain only unique ones since I have used member function.
    Overnight I got another idea by maintaining the list box entries unique by appending with pin's bBox which works fine. But still wondering how to do if entries are not unique.
    Ramakrishnan
    Andrew Beckett over 7 years ago in reply to RK56
    Ramakrishnan,
    How about something like this?
    let((scrList dstList usedCount)
        usedCount = makeTable('usedCount 0)
        foreach(ele scrList
            usedCount[ele] = usedCount[ele] + 1;
            if(zerop(usedCount[x]) then
                t
            else
                usedCount[x] = usedCount[x] - 1
                nil
  • RK56
    Thanks for the solution. I have never thought of using a if-else block inside setoff. Something new I learnt.
    On a related topic, I see some trouble in doing multiple selection by dragging or holding shift in a list box when the entries are duplicate. The selection does not happen continuous, there are few unselected items in between. Is it a known issue? I am using  virtuoso version ICADV12.3-64b 12/04/2018 18:23.
    Thanks again
    -Ramakrishnan
    Hi Ramakrishnan,
    Yes, I see that slightly odd behaviour too. I thought something felt odd yesterday when I was trying this out, but I didn't play with it long enough to notice what wasn't right. I suggest you contact customer support with an example to get this fixed...
  • RK56
    Cadence case https://support.cadence.com/COSCaseDetailPage?CaseID=5000V00001JASMqQAP&pageName=COSCaseDetailPage&isNewCase=false&oMenu=46364198
    is created. Thanks for the support here.
    For completeness (should anyone else hit the same issue), the answer is to use ?valueByPosition t when creating the listbox field (I tried, and that solves it). The documentation is going to be updated to make this clear as being the correct approach when you have duplicate entries in the listbox fields.
  • RK56
    Thanks Andrew.
    Just out of curiosity:  Is the new updated documentation is available only with new Virtuoso versions or Cadence can do a background push to update the docs in my company?
    -Ramakrishnan
    Hi Ramakrishnan,
    The documentation change hasn't happened yet for a start, but when it does, it would be updated on support.cadence.com and in any new hot fix version you install. There is no mechanism to push anything to you (including documentation updates).
