  3. Loading ocean rdb results back into ADE XL GUI history ...
  • Subscribers 148
  • Views 2125
Loading ocean rdb results back into ADE XL GUI history tab
FormerMember
FormerMember over 7 years ago
I am using a script to copy many versions of parent ADE XL state and schematic with subtle changes for each schematic. Each child ADE XL ocean is run  and their results I would like to load as a history tab back into the original parent ADEXL GUI. All the child copies can then be deleted once results plotted.. Anyone know how to create history tabs in ADE XL that point to ocean results?
    Normally an OCEAN script would create a history that can be viewed interactively, but it sounds as if you're doing something other than that. Without knowing what you're doing, it's hard to answer.
    I would suggest this is taken up with customer support as we'd need to see your scripts (and need enough time to investigate what you're doing with a suitable test case). You certainly can't create a history in one cellView and then magically transfer it to another, but I'm not sure why you'd need to do that in the first place.
