  3. How to choose different section-endsection with a Global...
  • Views 15465
How to choose different section-endsection with a Global Variable in ADEXL?
oyayla
oyayla over 7 years ago
I am trying to run corner simulations(more than 100 let's say) and have more than one dspf files(extracted netllist) but I want to include only one of them depending on a Global variable.
Example: I have 2 vcos: one is LC-VCO and other is Ring-VCO  and I am muxing the output of these. I have vco_sel for mux control as Global variable. Depending on vco_sel, I want to choose to include either LC-VCO or Ring-VCO so that simulation runs faster.
I know that I can create different sections which include dspf files separately but I need to enable and disable corners separately and create many corners. And I can't run sweep for vco_sel in one simulation.
Is there a way to pass VAR("vco_sel") to the section/endsection of corner setup like a condition. I am open to any other solutions as well.
yayla
Version Info:
ICADV12.3 64b 500.21
spectre -W =>
Tool 'cadenceMMSIM' Current project version '16.10.479'
sub-version  16.1.0.479.isr9
  • oyayla
    Is there any suggestion to this issue?
    yayla
    Andrew Beckett over 7 years ago in reply to oyayla
    If this was urgent, you should have created a case with customer support.
    The simple answer is "no".
