  3. Create couple of layer combo box
  • Subscribers 150
  • Views 16210
Abhishek Iyer
Abhishek Iyer over 7 years ago
How to create two layer combo box like in 6.1.7 with two separate set of layers.
I'm using leCreateLayerField command to get the combo box fields, but unable to modify choices independently.
I've verified that using fieldName1->choices=list("layer purpose") can be used, but somehow fieldName2->choices also gets updated.
Summary
Basically I want to segregate available layers into two combo layer field (with filtering as in 6.1.7)
    I thought initially that this happened if you were using the ?syncedPaletteWindow option but it also happens if I give just ?techFile.
    You'll need to contact customer support so that a change request can be filed on your behalf.
  • Abhishek Iyer
    Abhishek Iyer over 7 years ago in reply to Andrew Beckett
    Thanks. I'll go ahead and file a cadence support case.
  • Mantayya M
    Mantayya M over 7 years ago
    how to Print ROUND shape metal in cadence using skill program.
    Andrew Beckett over 7 years ago in reply to Mantayya M
    Please read the Guidelines for the Custom IC SKILL Forum. This appears to have nothing to do with the post to which it is appended, and there's not enough information to know what you actually want. What does "Print ROUND shape metal" mean? Why is ROUND in capitals? Which application and version are you using? So please start a new thread with sufficient information to allow somebody a chance of being able to answer your question.
