  3. writing into file using skill
  • Replies 12
  • Subscribers 150
  • Views 24765
RAGHU2634
RAGHU2634 over 7 years ago
Hi ,
I want  to  write manual data into a new/existing  file based on condition met in program. Is there any available command or script to do this ?
Raghu
  • RK56
    RK56 over 7 years ago in reply to RAGHU2634 +1
    Hi, You have to close the file port. Try, close(stopM) -Ramakrishnan
  • mbracht
    mbracht over 7 years ago in reply to RK56 +1
    alternatively - if you want to see the file's content before closing the file descriptor - you might as well flush the buffer: (drain stopM)
  • Adam Kubacak
    Adam Kubacak over 7 years ago in reply to RAGHU2634 +1
    Raghu, there should be no error. I don't know what type of data are contained in your "stopLayers". It's probably a list, so then you have to you "%L" formatting. Look up fprintf function in Cadence…
  • RAGHU2634
    RAGHU2634 over 7 years ago in reply to Adam Kubacak
    Hi Adam ,
    I dont have access to cadence online support .Anyway Thanks,
    Andrew Beckett over 7 years ago in reply to RAGHU2634
    There's also a function on the forums to do the same thing: Flatten the list
    The link that Adam gave is actually a link to the SKILL Language User Guide, so you can access the same information there via the Help menus in Virtuoso or by running cdnshelp. No need to use Cadence Online Support for that.
