  3. writing into file using skill
  • Replies 12
  • Subscribers 150
  • Views 24754
RAGHU2634
RAGHU2634 over 7 years ago
Hi ,
I want  to  write manual data into a new/existing  file based on condition met in program. Is there any available command or script to do this ?
Raghu
  • RK56
    RK56 over 7 years ago in reply to RAGHU2634 +1
    Hi, You have to close the file port. Try, close(stopM) -Ramakrishnan
  • mbracht
    mbracht over 7 years ago in reply to RK56 +1
    alternatively - if you want to see the file's content before closing the file descriptor - you might as well flush the buffer: (drain stopM)
  • Adam Kubacak
    Adam Kubacak over 7 years ago in reply to RAGHU2634 +1
    Raghu, there should be no error. I don't know what type of data are contained in your "stopLayers". It's probably a list, so then you have to you "%L" formatting. Look up fprintf function in Cadence…
  • Adam Kubacak
    Raghu,
    targetFile = outfile(targetFileName "a")  ;"a"-append, "w"-overwrite
    fprintf(targetFile "%s" stringVariable)  ;or different variable type configuration
    close(targetFile)
    See the help for complete description of these functions.
  • RAGHU2634
    RAGHU2634 over 7 years ago in reply to Adam Kubacak
    Hi Adam,
    Thanks for the response .
    I gone through the above functions.
    I tried the below exactly
    stopM=outfile("./stopM1" "w")
    fprintf(stopM "%s"  stopLayers)
    The command executed without errors but it written nothing into file. Please let mw know where I am making mistake
    Rgahu
  • RK56
    close(stopM)
    -Ramakrishnan
  • mbracht
    (drain stopM)
  • Adam Kubacak
    Raghu,
    It's probably a list, so then you have to you "%L" formatting. Look up fprintf function in Cadence help.
  • RAGHU2634
    RAGHU2634 over 7 years ago in reply to mbracht
    thanks
  • RAGHU2634
    i was not closing the port so i was not seeing it
    thanks
  • RAGHU2634
    RAGHU2634 over 7 years ago in reply to RAGHU2634
    Hi Adam,
    In extension to the above question ,
    I have a list A which has individual elements & also lists inside lists . Can we make this list A as flatten one so that it has only elements & no lists inside .Please let me know how to handle this ?
    Raghu
  • Adam Kubacak
    Hello Raghu,
    try to search Cadence site better...
    Such a task is well described for instance here: Using mapcan for list flattening
  • Adam Kubacak
    Hello Raghu,
    Such a task is well described for instance here: List flattening
