  3. Plotting Templates
  • Views 16007
Plotting Templates
Conorp
Conorp over 7 years ago
I was hoping to create a plotting template for each test that I have in Assembler. However, Assembler also has its own plotting template that appears to override each of the Explorer plotting templates. So when I have the plotting template set to "(None)" in Assembler none of the Explorer templates appear to work.
It's possible to run all the tests in Assembler and create one huge template in Assembler but this is very unwieldy. It would make more sense for each test to have its own plotting template.
Is there a way around this? I would like Assembler to respect the plotting template of each individual test/Explorer view.
IC 6.1.8
    Andrew Beckett over 7 years ago +1
    I don't believe this is possible currently, but it's a good idea. Could you please contact customer support so that we can file this as an enhancement request on your behalf? Regards, Andrew.
  • Conorp
    Conorp over 7 years ago in reply to Andrew Beckett
    Thanks for your help Andrew.
    Conor
