  3. How do I pass the parameter values of the schematic to those...
  • Views 16417
How do I pass the parameter values of the schematic to those of the instances inside the schematic
lbodepu
lbodepu over 7 years ago
Hi ,
I created a schematic with a simple RLC network.
Then made a symbol for this schematic.
Now I am trying to pass the R, L ,C values from the schematic's CDF parameters.
I used something like this:
cv=dbOpenCellViewByType("Photonics_cadence" "Pd_schem" "schematic" "schematic" "w")
res=dbOpenCellViewByType("analogLib" "res" "symbol" "" "r")
cellId=ddGetObj("Photonics_cadence" "Pd_schem")
cdfId=cdfCreateBaseCellCDF(cellId)
param=cdfCreateParam(cdfId , ?name "Res_R0"
?prompt "Res_R0 (ohm)"
?defValue "100"
?type "string"
?display "artParameterInToolDisplay('Res_R0)"
?parseAsNumber "yes"
?parseAsCEL "yes" )
dbCreateParamInst(cv res "R1" 1:1 "R90" 1 list(list("r" "string" param~>value)) t)
The value of R1 is by default 100.
However when I am trying to change the param  "Res_R0" from the property box of the schematic symbol, its not reflected in the R0.
Am I missing something.
    Yes. Set the value of "r" on the instance R1 to be pPar("Res_R0") - so:
    dbCreateParamInst(cv res "R1" 1:1 "R90" 1 list(list("r" "string" "pPar(\"Res_R0\")")) t)
  • lbodepu
    lbodepu over 7 years ago in reply to Andrew Beckett
    Thank you Andrew :)
