  3. writing into output file
  • Replies 10
  • Subscribers 150
  • Views 20736
RAGHU2634
RAGHU2634 over 7 years ago
I have an input file\reference file . Based on a condition met in program I want to add prefix (# or ;)  before lines into output file using line number.
Raghu
  • mbracht
    mbracht over 7 years ago
    Hi Raghu,
    Reading through a file and based on a condition prepending a comment characters to the lines is fairly easy:
    (let (from file)
       from = (infile "/tmp/test.il") ||
          (error "cannot open file...")
       (while (gets line from)
          (if <yourCondition>
             (println (strcat "# " line))
             (println line))))
    I don't understand though what you want to do with the line number, can you please elaborate on this
    Max
  • RAGHU2634
    RAGHU2634 over 7 years ago in reply to mbracht
    Hi Max,
    I want to add prefix using line numbers.Is this possible ?
    Andrew Beckett over 7 years ago in reply to RAGHU2634
    Your questions are very poorly formed, and so a lot of guesswork is involved as to what you're really asking. I'm really surprised you cannot work out the answers if they are as simple as we're guessing they are.
    let((from to lineNum line)
      from=infile("input.txt")
      to=outfile("output.txt")
      lineNum=1
      ; no \n in the fprintf because gets leaves the \n in each line read
      while(gets(line from)
        if(lineNum>5  ; i.e. some condition
          fprintf(to "#%d %s" line)
        else
          fprintf(to "%s" line)
      close(from)
      close(to)
  • RAGHU2634
    RAGHU2634 over 7 years ago in reply to Andrew Beckett
    apologies Andrew.
    I will avoid asking simple things
    Raghu
  • RAGHU2634
    what I am trying to do is copying my entire input file to output file & then uncomment  few lines in output file.Is it possible to uncomment lines using line number ?
    Raghu
    Yes, this is possible.
  • mbracht
    mbracht over 7 years ago in reply to RAGHU2634
    Raghu,
    You need to give us an example of a potential input and output file.
    I just can't understand why anybody would want to uncomment lines that have a certain line number but that's what you want to do isn't it?
    Max
  • RAGHU2634
    my input file is this :
    viaLayers(
    ("M1" "drawing") V1 ("M2" "drawing") t
    ("M2" "drawing") V2 ("M3" "drawing") t
    My output file should be :
    viaLayers(
    #("M1" "drawing") V1 ("M2" "drawing") t
    Let me know how I can do this
    Raghu
  • mbracht
    name your input file /tmp/in.tf and then:
    let( (from to (lineNum 0) line)
       from=infile("/tmp/in.tf")
       to=outfile("/tmp/out.tf")
          if(lineNum==1
             fprintf(to "# %s" line)
             fprintf(to "%s" line))
          lineNum++)
       close(from)
       close(to))
  • RAGHU2634
    my output is coming something like this
    "viaLayers(\n"#"(\"M1\" \"drawing\") V1 (\"M2\" \"drawing\") t\n""(\"M2\" \"drawing\") V2 (\"M3\" \"drawing\") t\n"")\n""\n"
    with lots of " & \n" .
    Raghu
